Trying to install TIS2000 software, problems !
Old Jan 26, 2016 | 11:10 PM
SG Lou's Avatar
SG Lou
Default Trying to install TIS2000 software, problems !
Anyone who has successfully installed the TIS 2000 software................................ .....HELP
Ok so I load the first disc, let it do it's thing, install USB thing when prompted, click on start up icon to update via 2nd disc, get half way through loading and i get an error message stating it cannot load, uninstall TIS 2000 and try again !
Could I have a bad Disc 2 or am I doing something wrong?
This is all the info that was provided via a notepad file:
How to Install:
1, insert tis_1 Disc and click Autorun.exe
2, click next, select english, Com1, standalone,NAO
3, select "USB Security KEY", Continue, oK, Continue Anyway
4,ope TIS2000, insert TIS_2 Disc,start update
5, Run Tis_usb-key.exe
6, Insert the usb-key
All ok
Old Jan 26, 2016 | 11:56 PM
SG Lou's Avatar
SG Lou
update:As stated above...with no luck.
Take a look at the picture below:
The 3 disc set on the left is what I have been trying to load with no luck.
Those are burned copies that they send you.
The disc on the right, you can see Bosch printed on it. Those disc's were included as well. One was a CD the other a DVD. I loaded the CD and it wouldn't install, eject the CD and load the DVD and BINGO...Program installed !
I won't know for sure until I hook up the Tech2 Scanner and start messing with it . !
Old Jan 27, 2016 | 05:36 AM
dadaroo's Avatar
dadaroo
I thought you needed to have Windows Professional XP. I loaded it onto a Windows 7 laptop using VMWare. We'll see how it works for you.
Mr. Sam
Old Jan 27, 2016 | 10:28 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
the cd disc is just a "how to" program tells you about the Tech 2, open it and select auto run !!!!!
Old Jan 27, 2016 | 10:46 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Lou this is a PDF file the same as the cd disc !!
File Type: pdf
zachaeous's Avatar
zachaeous
TIS software was sent to me the same way. I had trouble with my dvd drive reading the dvds. I tried several times as you did and finally got success. The program should run on any 32 bit version of windows. I have it on windows 8.1 x32 and it runs fine as well I tried on windows 10 32 bit and it installed ok!. It will not run on 64 bit operating systems directly. Good luck with your new toy.
Old Jan 27, 2016 | 11:26 AM
SG Lou's Avatar
SG Lou
TIS Program is loaded onto a lap top with the 32 bit WinXP Pro op system. I purchased this laptop just for this !
Old Jan 27, 2016 | 02:07 PM
SG Lou's Avatar
SG Lou
I already have this Paul, printed up in color and bound in a book format
Thanks though
To Trying to install TIS2000 software, problems !
