LED halo malfunction
Old Jan 29, 2016 | 05:27 AM
t56mike's Avatar
t56mike
Default LED halo malfunction
I just noticed today that when my headlights are on my inner passenger side led halo mod taillight doesn't light up the inner portion of the light when I apply the brakes. However when the hazards or turn signal is activated the outer halo flashes instead of the inner portion. Now this only with headlights/parking lights on. If i turn off the lights it operates normally. Any ideas?
Old Jan 29, 2016 | 08:51 AM
GCG's Avatar
GCG
Dismount it, clean the contacts and give it a try. If still messed up, it might be that one of the mod wires is pinched between the board and the back case causing a puncture in the insulation, or an internal failure. Do you still have warranty? If yes, and cleaning the contacts and resitting the plug doesn't solve it, you might want to contact the vendor.
Please, let us know how it goes
Old Jan 30, 2016 | 09:21 AM
t56mike's Avatar
t56mike
I fixed it this morning. Turns out the green wire that goes to the socket was cut. Spliced it together and it worked like a charm.
Old Jan 30, 2016 | 10:05 AM
GCG's Avatar
GCG
I'm glad you were able to find the cause and fix it!
How could that have happened?
Old Jan 30, 2016 | 11:02 PM
Good news that it was something simple.
Old Jan 31, 2016 | 02:16 AM
t56mike's Avatar
t56mike
It happened because the previous owner was a hack at electrical mods. Even though he was an aicraft avionics mechanic before. He had spliced in speaker wire for some reason. By spliced i mean twisted wires together then wrapped it with electrical tape
Old Jan 31, 2016 | 10:50 AM
GCG's Avatar
GCG
Shame on him! I hope he didn't do the same to the airplanes he worked on
Old Jan 31, 2016 | 01:03 PM
tmatthews's Avatar
tmatthews
After all these years in aviation, I still can not believe what I find and what some people claim they can do.
Old Jan 31, 2016 | 01:26 PM
ZZ06's Avatar
ZZ06
Hahaha......you might be frightened at what goes on for maintenance on an aircraft sometimes. Everything isn't as always as "professional" as they appear.
To LED halo malfunction
