C-5 Jack
Old Aug 31, 2002 | 04:25 PM
wcj's Avatar
wcj
Default C-5 Jack
don't know if anyone is interested or not but I just altered a Sears sissor jack by lowering the jack pad approx 7\8 to 1" by redrilling the existing pin holes in the pad. I removed the shoulders from the original pins by grinding them down making sure that I didn't shorten the pins at all so that after the re drilling of the mounting holes I was able to reuse the original pins by re peining them. It now give me a height collapled of 3 5\8". I am able to slide the jack under the front rail of the car with a jack pad in the chassis. If you weld a pin to the top pad of the existing jack, you wouldn't have to use a jack pad since the existing pad on the jack is small enough to fit the opening between the chassis and the body of the car. I am also able to jack the car up enough to remove a tire if necessary. I don't know what the collapsed height has to be if the car has a flat. However this helps me out I I want to do any maintenance on the brakes or front end without habing to pull out the floor jack or rino ramps especially if I only want to work on one side at at time. I didn't try putting jackstands under anything yet, but I suppose they would fit under the lower control arms. hope this is some use to someone. WCj : :U :chevy ;)
