HELP, Electrical System Gone to Hell
I bought the battery in May of 2002 from Sears (had it for 4 months), but I guess the strain from the shorted fuse made it weak. So I went to Sears, they replaced it free of charge, as the warranty stated. The mechanic from Sears said that he tested the car and a bad alternator came up. I said okay, I’ll take it to Vandergriff to get it tested again.
I left it at Vandergriff for an hour and was called and told that there was nothing wrong with the alternator. My gauge said that the battery had 13.0 volts, but the battery’s actual voltage was 13.9: “voltage at BCM is .8V less than battery. Car has interior voltage drop.” – from the Invoice.
So I went to pick up the car and learned that the whole electrical system had gone to HELL. With the door closed, NONE of the gauges work, at all, when the car is started. And there are a bunch of tiny As in the DIC. Pressing reset doesn’t do anything. My speedometer stays at 0, along with my RPMs…gas needle stays at E. BUT when you open the door to a certain degree, all the gauges come to life, just like when you start the car. I don’t understand.
The Vandergriff consultant said that they didn’t touch the electrical system…their electrical guy wasn’t there today. He also said that Sears had messed up putting the battery in, that they had crossed some wires in the battery, which I didn’t understand, since I drove it from Sears to Vandergriff without any problems. WTH!!!
It seems Vandergriff doesn’t want to take any responsibility for what happened to it while they had it. It doesn’t seem to me that the car would just stop working; it’s too much of a coincidence. I am visiting from college for the weekend and it seems I’m gonna have to leave my car until the next weekend. The Vandergriff consultant said that it might be from the battery leaking into the computer, but I was never even told that the battery ever leaked. It was a new battery!
What do you guys think they did or what happened?
Very depressed,
Haroon
1997 Torch Red Corvette Coupe - Vortex Ram Air, Z06 Chrome Wheels, Throttle Body Bypass, Advanced Timing Kit, Air Coupler, Exhaust Billet Plate, A&A Exhaust Mod, Exhaust Tips, Red Calipers, Baer EradiSpeed Rotors
Try removing the battery and the battery tray and checking for evidence of battery acid having leaked down into this area. You may need to remove the inner fender liner, but I was able to see the damage done to mine before I did that. Hopefully, your PCM isn't fried and all you'll need to replace is some wiring. I was lucky and caught mine before it did any real damage. I replaced my bettery with the new Delco AGM glass mat battery. These batteries have no acid to leak.
If you don't find any evidence of an acid leak, check for a wet or damp carpet on the passenger side in the footwell area. Sometimes the A/C drain will clog and back water up into the BCM (Body Control Module) computer located in the electrical center under the floor there. This has also caused some owner's electrical systems to "throw a fit" and in several cases stop working altogether.
Good luck.
[Modified by redriverjohn, 8:32 PM 8/31/2002]
I don't understand what the crossed wires could be, how could I have driven the car if the wires were crossed?
When a dealership does a battery and generator diagnostics test are the battery terminals unhooked? I'm now thinking that the dealership might have crossed the leads and then realizing it, fixed it, but with the damage already done. Could that cause the onboard electronics to go beserk?
Haroon
[Modified by stocksure, 11:18 PM 8/31/2002]
The connectors for the doors are located in the rubber grommet that is visable when you open the door.Because all the modules in the C5 communicate with each other,a poor connection at this connector will cause other systems to go bezerk.Continuous opening and closing of the doors can cause poor contact of these connector pins...
Haroon
