Thinking about replacing wires, what set do u use?
Old Aug 31, 2002 | 06:26 PM
whip383's Avatar
whip383
Default Thinking about replacing wires, what set do u use?
Changing out the ngk's, thought might as well do the wires, got about 65k on the stock set. any ideas?
Thanks,
Chan
Old Aug 31, 2002 | 06:34 PM
C5Cemo's Avatar
C5Cemo
Default Re: Thinking about replacing wires, what set do u use? (whip383)
I have been more than satisifed with the Taylor ThunderVolt 50s...10.4 MM...I bought last year. Very well built and can take the heat....literally. The number 2 cylinder wire is practically touching the FLP headers and it shows no signs of damage at all and I am not using any cool socks to help it out.
Now, the standard Taylor wires are not even close to the quality of the ThunderVolts and I would stay away from those....they aren't hand inspected and tested like the ThunderVolts are and it shows.
:cheers:
Old Aug 31, 2002 | 06:42 PM
MelloYellow's Avatar
MelloYellow
Taylor 10.4mm's should give you good heat protection.
Old Aug 31, 2002 | 07:09 PM
BLUTHUNDER's Avatar
BLUTHUNDER
Default Re: Thinking about replacing wires, what set do u use? (MelloYellow)
Chan , when my header was frying my #5 & #7 wire i had a chance to try them all :lol: ( Taylor , Factory , MSD's ,JBA etc..)
I never noticed a performance difference between the different gauges or various Manufacturer's..But i personally prefer the MSD wires, you can actually bend the boot slightly so they are not touching the headers.
There also very easy to slide on and off.
Good Luck !
:cheers:
Jeff
Old Aug 31, 2002 | 07:20 PM
Xssesive's Avatar
Xssesive
Default Re: Thinking about replacing wires, what set do u use? (BLUTHUNDER)
Magnecor also makes a very good wire, and accepts stock wire shield. :yesnod:
[Modified by Xssesive, 5:23 PM 8/31/2002]
Old Sep 1, 2002 | 01:05 AM
pkmoose's Avatar
pkmoose
Cruise-In III Veteran
I replaced stock with MSD's, and they work just fine.
Old Sep 1, 2002 | 12:30 PM
ddawson's Avatar
ddawson
Default Re: Thinking about replacing wires, what set do u use? (Xssesive)
Magnecor for me.
Old Sep 1, 2002 | 12:43 PM
billiam01's Avatar
billiam01
I'm very happy with the GMPP LS1 wires that I had installed with cool socks and B&B headers. :chevy
Old Sep 1, 2002 | 01:32 PM
steve badalamenti's Avatar
steve badalamenti
What's wrong with replacing them with stock wires?
At least you know the shields will fit.
Old Sep 1, 2002 | 01:36 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
MSD's are what I have on my car now. :yesnod:
vetterdstr :cheers:
Old Sep 1, 2002 | 01:52 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Thinking about replacing wires, what set do u use? (vetterdstr)
MSD ... the red wires look cool too.
Old Sep 1, 2002 | 03:02 PM
urslooow's Avatar
urslooow
go the msd's w/ beru plugs for the SC
Old Sep 1, 2002 | 03:12 PM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
Another vote for the red GMPP wires. No durability or header issues here so far. :)
Old Sep 1, 2002 | 03:16 PM
RyanC7's Avatar
RyanC7
Default Re: Thinking about replacing wires, what set do u use? (ToplessTexan)
I went MSD .....
:seeya
Old Sep 1, 2002 | 03:37 PM
RCswish's Avatar
RCswish
Default Re: Thinking about replacing wires, what set do u use? (Ryan2002C5)
The MSD's don't touch my Headers which is goooood. :D
Old Sep 1, 2002 | 04:12 PM
Crushinator's Avatar
Crushinator
Default Re: Thinking about replacing wires, what set do u use? (pkmoose)
:yesnod: I am very happy with my MSD's as well.
Old Sep 1, 2002 | 05:58 PM
SvenOdin's Avatar
SvenOdin
I got the Taylor 8mm Spiro Pro's.
:cheers:
To Thinking about replacing wires, what set do u use?
Old Sep 1, 2002 | 06:03 PM
rfgoss1's Avatar
rfgoss1
I bought some really nice wires from LGMotorsports last week. they have a kevlar heat shield and some other beefy stuff, but you can ask Justin at LG for more details. They look great too.
Randy :cheers:
Old Sep 2, 2002 | 02:07 AM
whip383's Avatar
whip383
Default Re: Thinking about replacing wires, what set do u use? (rfgoss1)
Well it seems like MSD are taking the ticket. I think summit has them for like 50 bucks, ill order them tonight. thanks all
Chan :cheers:
Old Sep 2, 2002 | 02:27 AM
ScreaminDemon's Avatar
ScreaminDemon
I used the MSD 8.5 universal wires, cut to fit. Used the stock plug ends and the metal sheaths. They were they only thing I could find to clear valvecovers. See pic;
