Squealing belt(s)
Old Feb 10, 2016 | 01:41 PM
mrlmd's Avatar
mrlmd
I'm not wanting to argue with you, but if you remove the belts (I assume you mean both of them) and run the car, you expect to tell if your AC tensioner is the culprit? Good luck with that. BTW, you haven't even established yet which belt and it's components are actually making the noise.
Again, search is your friend.
Old Feb 12, 2016 | 02:51 PM
midnight01's Avatar
midnight01
I took the belts off today after all the tensioner pulleys came in from Amazon. When I looked down at the 1st tensioner near the water pump for the main belt I noticed a large amount of dirt around the area the belt transfers. I cleaned the dirt off and decided to throw the old belt on again. The squeal was gone. The tensioner pulley was filthy and the reason the belts were squeaking. Just to be safe I replaced the upper belt tensioner and put a gatorback belt on, replaced the AC belt as well. This weekend I will be installing my Borla exhaust that came in today so at the same time the car is up on jacks I'm replacing all the pulleys.
Old Feb 12, 2016 | 03:33 PM
Christian327's Avatar
Christian327
Thats awesome bro, glad everything got figured out! and let us know how you enjoy the borlas! I installed magnaflows earlier last year and enjoy them but I was super close to getting the borlas.
Old Feb 13, 2016 | 05:35 PM
mrlmd's Avatar
mrlmd
Well that should do it, it should be nice and quiet now with both belts and all 4 pulleys changed. It took a while but you'll be much happier now.
Old Feb 13, 2016 | 07:30 PM
midnight01's Avatar
midnight01
Agreed, I waited to install my new exhaust (Borla) until after this was resolved. i installed it today and it finally sounds like a sports car should sound
