"Emergency" Brake Adjustment
Old Aug 31, 2002 | 09:52 PM
Greg00Coupe's Avatar
Greg00Coupe
Default "Emergency" Brake Adjustment
Since I had a rear tire off for the flat repair if figured I'd venture into adjusting the emergency brake. I ran the star adjuster out 25 notches and while it's an improvement probably not enough but OK for now.
My question is that I understand the adjustment is suppose to be self adjusting. Supposedly as you drift backwords and pull up on the brake handle a few times it snugs up. I could never get mine to do this but the adjuster was pretty much tight and maybe was not free enough to self adjust. Does anyone know if there is truly a self adjusting feature?
Old Aug 31, 2002 | 09:58 PM
redriverjohn's Avatar
redriverjohn
Default Re: "Emergency" Brake Adjustment (Greg00Coupe)
According to the service manual, there is.
[Modified by redriverjohn, 7:58 PM 8/31/2002]
Old Sep 1, 2002 | 12:27 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
I have never had success with the Pull the lever approach... :nono: THe best thing to do is manually adjust the shoes inside the rear caliper. :smash: :yesnod:
vetterdstr :cheers:
Old Sep 2, 2002 | 03:51 AM
alc2001's Avatar
alc2001
Default Re: "Emergency" Brake Adjustment (redriverjohn)
The only self adjusting feature I have found in the 2001 service manual is the automatic cable slack take up by the ratchet in the lever mech. This does not help if the problem is shoe-to-drum clearance which can be taken up only by the star wheel adjuster. This requires removing the rear rotors as there is no external access. I took my rotors off and adjusted the star wheel several weeks ago and the emergency brake works great now. I studied the star wheel mech very closely and can see no way that it can self-adjust. The detent spring is so tight that it takes a lot of effort to pry it to the next notch. The service manual makes no reference to self adjustment of the shoe-to-drum clearance. In fact says to remove rotors and manually adjust star wheel. What a PITA!
To "Emergency" Brake Adjustment
