Does anyone have, or know were I can locate what ALL the stock settings are on the PCM like (temperture fan settings, shift point, etc) for a stock 2001 LS1 auto 3:15 gear?
What are your new settings on PCM after installation of new port and polished heads and cam?
When new port and polished heads and cam were install, did you have PCM reprogram before or after installation?
Do you need to have PCM reprogram if cam is 217/221 .553/.553 116?
Re: PCM reprogrammed for 2001 LS1 auto, 3:15 gear (goatvet)
I would think getting it dyno tuned would be the way to go after H/C install. Check with Ed Wright at Fastchip or another good tuner for before and after settings.
