Electrical gremlins driving me crazy
I guess I am finally at a point where my car is starting to give me some attitude. I am dealing with some electrical gremlins, which I am sure are no mystery for the combined knowledge of this forum.
First, I installed orange/clear LED driving lights in the front. I got the hyper-flash harness and fixed the rapid blinking. For a whole summer season. However, what has happened now is that when I use the turn signals, they would blink and then stay lit without blinking. Sometimes they would work just fine over an hour and during repeated use. Other times they would get "stuck" after the first blink. Sometimes they would blink three/four times and then get "stuck". Once they are stuck, there is no changing that. Unless I turn off the car and start it again. It drives me crazy.
Second, I installed LED bulbs in my reverse lights. Now, at night, when my headlights are on, my reverse lights are on in a really weird way even if the car is in a forward gear. The left side is just barely lit. Like just a little dim afterglow. The right side, however is full on all the time no matter what if the headlights are on.
Third, I got a message on my DTC screen saying "active handling warming up". This made me chuckle and panic in the same time. What the hell does it mean? I immediately checked my codes and it showed me no codes. When the message appeared, I cleared it, but the amber icon with rear of the car and skid marks stayed lit. After driving like that for about five miles and turning the car off, it disappeared when the car was turned back on.
Please help me with solving any/all of these issues.
Thanks in advance.
Jamieo, I don't remember if I got the harness from you, but it is very possible. It works like a charm. No complaints there. From the search I made, I gathered I pretty much need to change the relay. It is pain because the dash needs to come out, but I also found some very old posts on here, explaining that it could be done through the radio opening. So I guess I will be doing that.
Now, could anyone chime in about the issue with my reverse lights? Anyone had similar problem? Or should I just go back to regular bulbs?
As for your "TC warming up" issue, I wouldn't worry about it. I agree with 8vette7 on this one.
I am completely lost when it comes to electronics. Hahahha
