So i am going to pick up a bbk intake tomorrow for $100 of Craigslist. I have a 99 ls1 with the stock manifold. My question is will i have to change out the TB or can i keep my old one. Also it comes with no hardware so will i be able to install it using the old hardware or will i have to buy extras to install it. Also lastly where can i find a how to manual on installing a intake on an ls1. Thank you
You will need the intake bolts for bbk intake. I did this swap i my car. You can use your stock tb. There is a spacer to use to go from stock to the 80mm opening. Not a necessity, but i have it if you really want it..
Here is the bolt kit i got for mine
[Url]http://m.ebay.com/itm/LSX-LS1-BBK-SSI-Intake-Manifold-Bolts-/321112267640?nav=SEARCH
Instructions for installation here
