Control arms help
Old Mar 5, 2016 | 12:09 PM
71corv's Avatar
71corv
St. Jude Donor '08
Default Control arms help
Need help with the installation of the rear upper arm. Took the drivers side off and removed and cleaned the poly bushings. Re-lubed everything and re- installed the bushings. Here's the problem: have tried to install the arm but am not having any success with getting the arm to go on. Have not been able to get the 3 attachment points connected. Appreciate any help I can get. Thanks.
This is for a 02 Z06.
Gene
