NO Tailights
Old Mar 6, 2016 | 01:43 PM
The Highlander's Avatar
The Highlander
Default NO Tailights
Hi,
My c5 has no tail lights. I do have dash light and running lights. Any thoughts on this?
THanks
Old Mar 6, 2016 | 02:04 PM
v6turbo87's Avatar
v6turbo87
Originally Posted by The Highlander
Hi,
THanks
Have you checked for a blown fuse?
Old Mar 6, 2016 | 02:08 PM
The Highlander
Yes. I did. They are all good. I may have a ground problem on the back harness.
Old Mar 6, 2016 | 02:44 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
You mean the lights just disappeared? Did you call the cops? Who would steal tail lights? That's just weird...
... Oh, you must mean your tail lights do not illuminate... That's a bit different.
Old Mar 7, 2016 | 01:47 PM
Ray 2000 C5 FRC's Avatar
Ray 2000 C5 FRC
Hi,
THanks
Question: Do you have aftermarket tail light lens (european type) that uses an aftermarket wiring harness to "connect" to the original factory wiring harness. If so, check the connector under the right rear fender well. My connector/pins somehow over time got disconnected and caused the tail lights and brake lights not to function. I ended purchasing a new wiring harness, problem solved.
Old Mar 7, 2016 | 01:54 PM
The Highlander
No. I have the halo. It was working before i did the harness swap. I just thought it was a common problem on these cars
Old Mar 7, 2016 | 05:40 PM
dadaroo's Avatar
dadaroo
So, you did a harness swap for some reason and they now don't work????????????
Mr. Sam
To NO Tailights
