instrument buttons cluster
Old Mar 10, 2016 | 08:56 AM
jjnitrox's Avatar
jjnitrox
Default instrument buttons cluster
Hi Guys:
I have a 04 convertible and I'm having problems with the buttons cluster on the right side this are buttons that you use for to check gauges, reset etc. My problem is that the top 2 buttons wont light up. I check lights and they are off when I hit the dash board with my hand they light up again. I bought another button cluster because I was not satisfied doing this and same thing happened. I check the connectors and every thing looks ok. Can anyone help me with this problem.
JJ
Old Mar 10, 2016 | 10:47 AM
dadaroo's Avatar
dadaroo
Better check/test the wiring and connectors. You probably have a loose pin/terminal.
Mr. Sam
Old Mar 10, 2016 | 11:02 AM
If both of the button clusters do the same thing, the connector would be the next logical place to look for a problem.
Old Mar 11, 2016 | 11:47 AM
huesmann's Avatar
huesmann
Are you saying that the buttons just don't like up properly, but that the buttons (when pressed) operate their assigned task normally? Sounds like a bad backlighting bulb to me.
Old Mar 11, 2016 | 04:09 PM
jjnitrox's Avatar
jjnitrox
yes they do the function correctly.
To instrument buttons cluster
