oil temp sensor wire diagram
Old Mar 10, 2016 | 01:16 PM
StealthFRC's Avatar
StealthFRC
Default oil temp sensor wire diagram
anyone have a diagram as to where these wires go? mine are broken near the harness and i cant get access to strip them back and solder some extensions on. id like to just run all new wires from wherever then come from if possible.
do they go to the pcm?
Old Mar 12, 2016 | 06:23 PM
ZZ06's Avatar
ZZ06
This what you lookin for?
Old Mar 12, 2016 | 09:05 PM
StealthFRC's Avatar
StealthFRC
It is, just wish I knew how to read it lol
Old Mar 12, 2016 | 10:13 PM
ZZ06's Avatar
ZZ06
Im not sure of the wires you broke. A picture would help. Here are the grounds as well. G105 goes to the block I believe
File Type: docx
Old Mar 13, 2016 | 09:03 AM
dadaroo's Avatar
dadaroo
That schematic is NOT what you need. You are wanting the oil temperature sensor info.
What year do you have??????
Mr. Sam
Old Mar 13, 2016 | 09:10 AM
v6turbo87's Avatar
v6turbo87
That schematic does not have the oil TEMPERATURE sensor on it so it is not the one you need.
Old Mar 13, 2016 | 09:26 AM
dadaroo's Avatar
dadaroo
Just verified all years go to the IPC. Do you really want to pull new wires from there?
Mr. Sam
Old Mar 13, 2016 | 01:04 PM
StealthFRC's Avatar
StealthFRC
Is there somewhere I can intersect it from? The diagram he posted does have the temp sensor. It's on the bottom left, it's just at the ipc.
I'd rather not go from there but I don't think the ipc is hard to pull? I'm sure it's easyier then pulling a turbo or down pipe that's for sure lol.
I made a temp fix, hopefully it holds for awhile, if not I'm pulling new wire.
Old Mar 13, 2016 | 02:56 PM
v6turbo87's Avatar
v6turbo87
That is the COOLANT temp GAUGE not the OIL temp sensor. Your post says you are looking for the OIL temp sensor. Which are you looking for?
Old Mar 13, 2016 | 04:23 PM
StealthFRC's Avatar
StealthFRC
Sorry your correct. Yes I'm looking for OIL temp
Thanks again
Old Mar 14, 2016 | 01:01 AM
ZZ06's Avatar
ZZ06
Sorry about that. I believe I have the wiring diagram ur lookin for just having trouble posting it
Old Mar 14, 2016 | 01:03 AM
StealthFRC's Avatar
StealthFRC
need an email?
Old Mar 14, 2016 | 01:54 AM
ZZ06's Avatar
ZZ06
Try this
Old Mar 14, 2016 | 02:06 AM
StealthFRC's Avatar
StealthFRC
this is the plug that plugs into the gauge cluster correct?
Old Mar 14, 2016 | 02:09 AM
ZZ06's Avatar
ZZ06
Diagram states its the sensor and its located at the bottom left side of the motor. Which is where its located. This is for a 2000 but all my graphs have it in the same location.
Old Mar 14, 2016 | 12:19 PM
StealthFRC's Avatar
StealthFRC
i see that but it says the wires go to pins b8 and a10 but are those the pins on the plug behind the gauge cluster?
Old Mar 14, 2016 | 10:45 PM
ZZ06's Avatar
ZZ06
Yes they run to the IPC
To oil temp sensor wire diagram
Old Mar 15, 2016 | 07:03 PM
StealthFRC's Avatar
StealthFRC
Ok great, thanks. I'm hoping the fix I just did holds for awhile, if not I'll be tuning new wire.
Thanks for your help.
Old Mar 9, 2021 | 08:01 PM
gbm's Avatar
gbm
did you ever have to run new wire, or did your fix hold? Mine appear shorted
Old Apr 28, 2022 | 11:19 AM
helga203's Avatar
helga203
Default oil temp
Just curious what oil temp for a LS base engine is safe before WOT and and how many miles is out of the safe Wot. !000hp to 300hp
