Electrical problems already
Old Mar 18, 2016 | 02:23 PM
01sketchyvert's Avatar
01sketchyvert
Default Electrical problems already
Hello everyone.
I've had my 01 vert for about 3 weeks now and it seems that the electrical gremlins have already set in. I have read several different threads on this problem and the sticky that was posted here. My first problem was the flashing cluster with reduced engine power, trac, handling, abs, all gauges going to default except speed/tach/volts, and the radio would quit when this all began. Turning the key off and back on real quick would usually cure the problem for 5-10 minutes and it would happen again. All of a sudden it quit happening. For about 2 weeks; then today it happened again, only this time the driver window will not go up and the lock won't work. The driver switch for windows and locks does not work at all, but the mirrors and memory seats do work, as does the speaker. Then the passenger window would not go up or down, when I wiggle the wires in the bellow at the passenger door I can get the passenger window and locks to work. At this point, with the passenger door working again, the driver switch will operate the passenger window and lock, but not the driver side still. Further investigation shows that the wires going into the connector that operates the passenger door lock/window, are loose in their sockets. So I pulled the driver bellow and checked the wires there, same problem but I can not make the window work even when pushing all of the wires tightly into the connector. I went ahead and pulled the passenger footwell panel and the fuse cover but was cut off with having to go back to work. I know this has been discussed before but I can not find this exact problem. Even if I can not get the dash lights and radio to quit messing up, I need the window to roll up because I'm going to Myrtle Beach's Run to the Sun show this weekend and need security.
Thanks everyone,
Blane
Old Mar 18, 2016 | 02:39 PM
Robert Perkins's Avatar
Robert Perkins
First thing is pull the DIC codes. Check battery read the battery direct with a multi meter. With car not running.Compare with your voltmeter reading how much difference? The C5 is very sensitive to voltage.
Old Mar 18, 2016 | 03:02 PM
01sketchyvert
Thanks for the response. I didn't have time to pull the codes yet, but I did check the battery. Running voltage is 14.24. Key off voltage is 12.46. Key on voltage is 12.31. The battery only has a RC of 110 and is 6 years old. I hadn't checked it yet. Maybe I can charge it, or just replace it?
Old Mar 18, 2016 | 03:26 PM
Robert Perkins
Just replace it it is bad, that should fix your problems.
Old Mar 18, 2016 | 03:31 PM
01sketchyvert
Okay, thank you. I think I should still go through all of my connectors whenever I have more time though. It's so odd to think the battery would drop just the drivers window though. Maybe the bcm or something isn't communicating because of the battery? Trying to understand why it does this, especially since it sees plenty of voltage when it is running. I will replace it today before we leave.
Blane
Old Mar 18, 2016 | 03:35 PM
Robert Perkins
The C5 is very voltage sensitive. After you replace the battery make sure all codes are clear and drive the car check for any new codes and report back. Good luck.
Old Mar 18, 2016 | 05:04 PM
Robert Perkins
The original poster stated the battery is six years old and I had him measure at the battery and only 12.31 with key on not running, battery is bad.
Old Mar 18, 2016 | 05:20 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Originally Posted by 8VETTE7
Before you replace the battery I would have it tested. Most parts stores will do that free of charge.
Your problem could be a battery on its way out or it could easily be the ignition switch, a well known problem item in the C5. The ignition switch is electrically between the battery and the electrical loads. Carbon buildup on the contact surfaces inside the ignition switch can prevent battery voltage from ever reaching the electrical loads and hence causing problems.
After having the battery tested I would use the info in the following 3 links to determine if the ignition switch is a problem and if so remove and repair or replace it:
diagnosis
http://forums.corvetteforum.com/1568186703-post64.html
removal
http://forums.corvetteforum.com/1571067145-post107.html
repair procedure
http://forums.corvetteforum.com/c5-t...ch-repair.html
One users review of ignition switch caused issues:
https://www.corvetteforum.com/forums...post1590674866
Old Mar 18, 2016 | 06:53 PM
ZZ06's Avatar
ZZ06
8VETTE7 beat me to it. Have a look see at your ignition switch.
Old Mar 18, 2016 | 07:58 PM
01sketchyvert
Thanks everyone for the replies. I had a battery tester at work and it showed the battery to be in good condition still. And since I am going out of town this weekend I did not bother with getting a battery, I will when I get back. I have decided to not take the vette. Since getting home I have gone through and checked al of the codes in the DIC. There is quite a list of them. U1016, u1255, u1064, u1096, u1301, u1160, b2202, b2284, b1255, b1064, b1016, b2283, b2285, u1300, c2100, c2105, c2110, and c2115. After clearing all of the codes the only one that would continually come back and not clear was B2284. I believe that is left door battery #2 low/issue. Driving home today I didn't have any issues with other lights flashing on the dash or radio issues and the passenger door works completely from both the driver side switches and the passenger side switches. The only thing that does not work is the driver side window and lock still. Also found out the 12v outlets do not work when trying to charge my phone. I have thought about the ignition switch before but haven't had the time to pull everything apart to get to it, and I won't be able to check it until after the weekend. Any quick thoughts on that code, or maybe it's at the module in the door itself? I will continue to post my findings until the problem is fixed. Thanks everyone.
Blane
Old Mar 18, 2016 | 08:00 PM
Robert Perkins
So you load tested the battery and it tested good?
Old Mar 18, 2016 | 08:12 PM
01sketchyvert
Yes sir it did. Did with a digital tester and then an old tester with the switch you hold for 10 seconds or so. Both showed it to be in good condition through RC and CCA on the digital.
Blane.
Old Mar 18, 2016 | 09:06 PM
01sketchyvert
I will say, I am going to be replacing it as soon as I get back due to age if nothing else. I will get either an optima or order a battery that is accepted among the forum.
Blane
Old Mar 19, 2016 | 05:30 PM
rrwirsi's Avatar
rrwirsi
Other than gas, a good battery is a must in the C5 to make it go. I replace every battery in my 3 cars after 4 years whether it needs it or not. After one episode with wifee being stranded, lesson is learned.
Old Mar 21, 2016 | 12:39 PM
dsmith4229's Avatar
dsmith4229
Cruising
If this happened after rain or wash.Reach under drivers side of car wind shield wiper and remove the utters clean them and put them in the hatch compartment. If problem still exists. Change out the wind shield wiper motor. Had same problem years ago. Have not had a problem since.
Old Mar 21, 2016 | 01:47 PM
01sketchyvert
Just checking in real quick. Have been at Run to the Sun this weekend, awesome show as always. I am getting the battery today, it's the ACDelco professional one. Seems everyone likes that or the optima red/yellow tops. We will see what happens. If that doesn't work, I will move on to the ignition switch and then the door itself. I have washed it a couple times but that hasn't seemed to bother it in the least bit, I will still check to see if I find anything in the wiper area. Thanks again everyone, I'll report my findings with the battery this evening.
Blane
Old Mar 21, 2016 | 07:05 PM
01sketchyvert
Quick update everyone. I replaced the battery with a 78 series acdelco professional. 800cca and 110rc. Believe that is what I need. I'm also going to invest in a float charger. It did not solve the driver side window and door lock problem. But, everything else seems to be working very well, the DIC shows a higher charging voltage now and it may even start a little quicker. I cleared all codes and drove it, the B2284 is still there, it never would clear. I went ahead and checked the rubber udders at the wiper, one had a lot of leaves in it but was all dry, I cleaned both out very well and rechecked, still nothing. I guess next step is ignition switch and then to the door itself. I also want to go through both door 6 pin connectors and redo all of the wires to make them tighter.
Blane
Old Mar 29, 2016 | 09:48 PM
01sketchyvert
Hello all. I wanted to update everyone on the status of my car. I was able to fix my problems. Upon removing my driver door panel, I found that I was not getting power to the driver side window and lock. I went through both door harnesses and fixed the connectors. After that I traced the wires back to the bcm and fuse panel. I was able to find some of the connectors there ever so slightly damp and corroded. After fixing all of the issues there I wad able to once again gain power at the door and everything works as it should. Hopefully fixing the connectors and replacing the battery, the dash will no longer light up randomly. I want to thank everyone again for the insight and helpful posts.
Blane
Old Mar 30, 2016 | 03:24 PM
jjc508520's Avatar
jjc508520
Thanks for the followup!
To Electrical problems already
