Need help lingenfelter lnc 2000 install
Old Mar 22, 2016 | 04:57 AM
Joe Z51's Avatar
Joe Z51
Default Need help lingenfelter lnc 2000 install
Anybody used a 2 step lingenfelter Lnc 2000 on an auto and used brake light switch as 12v trigger? Trying to figure out best place to tap into for the brake switch wiring. Thanks for any help.
Old Mar 22, 2016 | 06:36 AM
Chris Stewart's Avatar
Chris Stewart
I have a Harlan 2 step that I believe is similar. I use the brake switch to trigger it. The trick for me was my unit needs a ground to activate, and the footswitch signal is positive. So I ended up using a relay to reverse the signal and activate the 2 step.
Old Mar 22, 2016 | 06:46 AM
Joe Z51's Avatar
Joe Z51
Yeah mine uses the 12v. What wire did you tap the relay into? Also what car do you have I have a c5z. Thanks for the info
To Need help lingenfelter lnc 2000 install
