HVAC B0367 code
Old Mar 25, 2016 | 01:31 PM
Robert Perkins's Avatar
Robert Perkins
Default HVAC B0367 code
1998 Vert electronic climate control panel. Right side A/C flow down out of dash vents temp cold. Getting B0367 right actuator feedback open. Is there a fix or do I need to replace actuator. Also when heat is on does blow out floor vents and not dash switching to A/C flow switches to dash. I can clear code and it does come back after the A/c is selected.
Old Mar 27, 2016 | 04:31 PM
Robert Perkins
Reset fuse but after two cycles the fault code returns. Any other idea?
