Which header gaskets?
Old Mar 25, 2016 | 08:15 PM
bwill03z's Avatar
bwill03z
Default Which header gaskets?
I have a set of headers on their way and need to buy some gaskets, I'm not wanting to use the ones supplied. I know you can't go wrong with the factory GM gaskets, but do you guys prefer those or the Percy's "dead soft" gaskets?
Old Mar 25, 2016 | 08:35 PM
Smoken1's Avatar
Smoken1
You can re-use your old OEM ones or get new ones
Old Mar 25, 2016 | 08:47 PM
bwill03z's Avatar
bwill03z
Yeah I thought about reusing the stock one but I didn't want to take the risk of having a leak.
Old Mar 25, 2016 | 08:55 PM
Smoken1's Avatar
Smoken1
I reused my stock ones when I put my BBK shorties on with no problems. Then I went with Hinson Long tubes, So I bought new ones. Twice reused did not sit right with me
Old Mar 25, 2016 | 09:02 PM
bwill03z's Avatar
bwill03z
Well I bought my car with shorty headers on it already so I don't know if they used the factory gaskets, the gaskets that came with the pipes, or something else. So for piece of mind I am buying new.
Old Mar 25, 2016 | 09:11 PM
Smoken1's Avatar
Smoken1
Good idea
Old Mar 26, 2016 | 08:44 AM
Cutlassmaster's Avatar
Cutlassmaster
I used remflex and they work great. I think it was a 2008 part #.
Chris
Old Mar 26, 2016 | 09:14 AM
tbrowne's Avatar
tbrowne
Newer LS1 gaskets have 'D' shaped ports that match the exhaust ports on the heads. The 'D' shape doesn't seal well with the round ports on the headers. The 1997-2000 LS1 exhaust manifold gasket with round "O" shaped ports work best. The posts in the link below describe the problem.
https://www.corvetteforum.com/forums...sket-swap.html
Old Mar 26, 2016 | 09:20 AM
bwill03z's Avatar
bwill03z
I found that out doing some reaearch last night, but thanks for the info. I guess I will just go with the GM factory round ls1 gaskets.
Old Mar 26, 2016 | 02:31 PM
ZZ06's Avatar
ZZ06
http://www.gmpartsdirect.com/oe-gm/12617944
To Which header gaskets?
