Need some help guys.
The passenger side O2 extension plug fell onto my headers while I was driving causing a major misfire.
Brought the car back to my shop and put it on the lift. I noticed it was the plug. Changed it out and still misfire.
The whole passenger side coil pack is dead. The car starts but is running on 4 cylinders.
I check all the grounds. (Back of head bottom of block and starter side)
All the fuses are good too. The wire harness does not look to be burnt anywhere. I even swapped out the O2 sensors with other that I had and still the same problem.
I'm all out of options at this point.
I have searched and searched all leads to ground somewhere. But WHERE ?
I also notice when the car is on(misfiring) the MPH on the cluster is very dim when it's usually bright, leading to a ground. Right ?
Plugs/wires all new so I know it's not that.
Please any help is much appriciated. Thanks, Joe
Originally Posted by dadaroo
So on the driver side there is no power to the coils on the Pink wires when the ignition is ON?
Mr. Sam
, check for power at the coils... losing your front o2 sensor(s) will cause the car to run like crap but you shouldn't lose your coils, so something else is probably going on... I had a similar issue where I lost the passenger bank and it didn't take me long to find out why, no power at the coils and when I unplugged my extension harness this is what I found... after replacing the harness I haven't had an issue since, my only guess is maybe there was a loose terminal inside the connector causing it to get hot and melt
Gong to check for power with a volt meter now in a few. I hopes its just a geound somewhere and not a burnt engine harness. Everything else works
Problem solved. Changed the O2 on passenger side last night & nothing. Decide to go ahead and change the drivers side O2 and bam problem solved. Thanks for the help guys
Great but that makes no sense at all. Why did no coil on the passenger side have no power and now do? Also never heard of a bad O2 sensor causing backfires.
