HUD not lighting up?
Old Mar 27, 2016 | 03:11 PM
sureshot007's Avatar
sureshot007
Default HUD not lighting up?
So I recently bought a C5 and I am just getting around to checking out what's wrong with the HUD. I just assumed it was the "falling" problem, so I removed it today. Mechanically, it looks fine. I hooked it back up, and the adjustment motor does work, and the mirror does move. But I can't see any light coming out of it.
Do I just have a bad unit and need a new one? I'd hate to shell out the cash for another one just to hook it up and not work. Is there any way to bench test it to make it light up at all?
Old Mar 28, 2016 | 12:45 AM
UM Rebel's Avatar
UM Rebel
Would like some info on this also. I don't use my HUD, but like for everything to work. Tried to turn it on a few days ago and it doesn't light up.
Old Mar 28, 2016 | 07:54 AM
mike48750's Avatar
mike48750
I am also interested in gaining more info on this system. I use mine at night or in conditions of low light and love the fact I do not have to remove my eyes from the road to see how fast I am traveling. Mike
Old Mar 28, 2016 | 08:49 AM
Phanni's Avatar
Phanni
Are you sure the intensity is turned up? It's the slide ****,, in the up position it is at full intensity.
also, if you're wearing polarized sunglasses it is difficult to see.
Old Mar 28, 2016 | 08:50 AM
sureshot007
Yes, moving the slide up and down while staring directly at it from outside through the windshield. Made no difference.
Old Mar 28, 2016 | 09:47 AM
Phanni's Avatar
Phanni
It's made to be viewed from the inside.
Old Mar 28, 2016 | 09:50 AM
sureshot007
Yup, that's how I knew something was wrong in the first place - when I couldn't see it from the driver's seat.
So, after I removed it, and verified that the pivot pin isn't broken, I hooked it back up, and looked directly at the LCD screen (since it has to be plugged in, I had to stand outside the car and look through the windshield to get the right angle).
Old Mar 28, 2016 | 11:38 AM
dadaroo's Avatar
dadaroo
OK, I can provide the HUD power and ground circuits info for you but not at home now. If it works then it may be the controller or IPC itself.
Mr. Sam
Old Mar 28, 2016 | 11:39 AM
sureshot007
That would be fantastic! Thank you!
Old Mar 29, 2016 | 06:03 AM
dadaroo's Avatar
dadaroo
Here is the schematic, there are no connector views unfortunately.
https://www.dropbox.com/s/vx8p5eoshc...matic.pdf?dl=0
Mr. Sam
Old Apr 1, 2016 | 06:17 PM
sureshot007
I bought another HUD and hooked it up - no dice. Mirror still moves fine, but no lights.
Anyone that says removing the dash is easy is a liar. Maybe if you are comparing it to a college thermodynamics exam...
Old Apr 2, 2016 | 06:34 AM
dadaroo's Avatar
dadaroo
Did you check for lighting voltage from the controller to the left of the IPC?
Mr. Sam
Old Apr 2, 2016 | 05:37 PM
sureshot007
Crap, now I have a dead battery.
Old May 17, 2019 | 08:13 PM
Y-bodluvr's Avatar
Y-bodluvr
I’m having the same issue after taking the unit and Cluster our HUD control lighting is also out and amy battery completely drained in a day
Old May 18, 2019 | 02:41 AM
Moved to C5 Tech.
Old May 18, 2019 | 10:00 AM
Mickeyrx70's Avatar
Mickeyrx70
Old May 18, 2019 | 11:10 AM
Y-bodluvr's Avatar
Y-bodluvr
Im narrowing down this issue to something happening to either wires connection or bOard from removing the cluster or the HUD unit itself it stayed upright the whole time it was removed though both the HUD and the HUD controls illuminatrd before so this is very frustrating!
To HUD not lighting up?
