Next Question, if I get a ring job...
http://www.idavette.net/hib/02ls6/page2.htm
There are plenty of perfectly smooth-idling, emissions-passing, no-reprogramming-necessary cams available that will net you a hell of a lot better power increase than a puny LS6 stocker.---
Remember--it's STILL a stock cam, tuned with 60 year old men going to the golf course in mind....don't **** away a golden opportunity to get something in there worth having!! :cheers:
Pushrods
Spring
Valve Retainers
and i recommended the comp cam 212/218 or mti 218/218 if you want to spend some extra $$$ on this don't know you budget. hope this helps feel free to email if you any additional questions.
So, the bigger question becomes, now that you'll be paying the big bucks for mods, how big a cam do you really want? :jester
How much oil were you using before the ring job? I'm wondering how much I've got to be using before GM will make it right?
My car was somewhat erratic in its usage over its first 17k miles, but I definitely saw the low oil indicator several times, and my chrome exhaust tips were always black. The dealer had me come in and get a new PCV valve (also per the TSB), and at the same time they topped my oil off and said to come back at 1,000 miles. I drove fairly aggressively during that period, and I ended up using close to 2 quarts in that 1,000 miles. :eek:
After the ring job, I cleaned my exhaust tips, and about 700 miles later so far they are much cleaner. So, I'm assuming there's been a considerable improvement, and this after my car had some good spirited driving last week.
Good luck.
This dealer is willing to put in a cam and other speed parts that I bring him, he will only charge me the "extra" labor it takes to do these things with the motor out, which is very minimal.
See my sig for what I'm having done.
http://www.idavette.net/hib/02ls6/page5.htm
Bottom line, they seem to have done right with my car; it's just too bad they also couldn't do right with their customer relations. If I didn' love the styling and performance of this stinkin' car so much, I'd go elsewhere for my next purchase. :cuss
