lowering procedure
Old Apr 7, 2016 | 08:28 PM
Solofast's Avatar
Solofast
If the spring breaks it will drop the car down onto the bump stops and it will ride really harshly. It could sag to one side first but so what.
The car will push a lot and if it starts riding rough it can tend to knock the alignment out.
Shouldn't take more than a week to get a spring, even in Norway. It's not so heavy that you can't airfreight it from the USA.
Good luck
Old Apr 7, 2016 | 09:44 PM
Dave70's Avatar
Dave70
Not trying to steal your thread but I was hoping someone could offer some advice. Just bought my 01 Z06 the front is extremely low. The air dam is 1/4" from rubbing. The rear seems higher than stock. Is there a reason for this? I'll post a few pics. Also the car has aftermarket sways and endlinks of unknown manufacture. Not sure if the shocks are stock or not.
Old Apr 7, 2016 | 09:48 PM
Dave70's Avatar
Dave70
I'll post the pics later tonight phone won't let me post right now for some reason.
Old Apr 7, 2016 | 10:15 PM
Dave70's Avatar
Dave70
Front
Old Apr 7, 2016 | 10:22 PM
Dave70's Avatar
Dave70
Originally Posted by Dave70
Front
Shock and lowering bolt
Old Apr 7, 2016 | 10:24 PM
Dave70's Avatar
Dave70
Rear fender gap
Old Apr 7, 2016 | 10:25 PM
Dave70's Avatar
Dave70
Front fender gap
Old Apr 7, 2016 | 10:26 PM
Dave70's Avatar
Dave70
How she sits
Old Apr 8, 2016 | 12:31 AM
Verrückt ZR1's Avatar
Verrückt ZR1
How she sits
Dave,
Get in there and fix that stance immediately. Not a tough job to do at all. The front is lowered to its maximum, or damn near close. I'd raise the front two or three threads, and drop the back down as far as it'll go. See how that levels things out. Just remember to relieve the pressure on the front leaf springs before attempting to adjust the bolt. It won't go anywhere otherwise. Beautiful car you have, and it'll look even better once you correct the PO's strange lowering decisions.
Old Apr 8, 2016 | 12:55 AM
Dave70's Avatar
Dave70
Thanks. Going to be doing that this weekend along with new rotors and pads.
Old Apr 8, 2016 | 01:01 AM
Verrückt ZR1
Very nice. I replaced my rotors and brake pads about two months ago, and lowered my car a month later. Good luck with the install. As always, let us know if you're stuck.
Old Apr 8, 2016 | 07:22 AM
CorvetteC5Norway's Avatar
CorvetteC5Norway
Good luck
Thanks for the info. What I'm afraid of is that the tires will hit the fenders and destroy them. I have 9x19 ET 55 rims and 255/35-19 tires. They sit a little bit longer out into the fender than the originals...
The first weekend with nice weather is coming up now, so I will chance a smooth and easy trip with the car. The spring has been like this since I bought it (at least the height), and I have driven it quite hard, not broken yet. Let's cross thumbs.
I thought I'd strap some metal screw-straps (probably not what it's called in English) around the spring where its started to delaminate to keep it together. Since springs like this is made of long fibers, my limited technical insight tells me that it will help to stabilize it, but I could be wrong...
Old Apr 8, 2016 | 06:44 PM
  #33
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Is that bolt screwed all the way through the spring?? Is what appears to be a hex nut on the stud, actually the "threaded insert" that's molded into the spring? If so, it's pulled through the spring, and therefore, the spring is broken, I think.....
Old Apr 8, 2016 | 06:46 PM
  #34
leadfoot4's Avatar
leadfoot4
Originally Posted by CorvetteC5Norway
....I thought I'd strap some metal screw-straps (probably not what it's called in English) around the spring where its started to delaminate to keep it together. Since springs like this is made of long fibers, my limited technical insight tells me that it will help to stabilize it, but I could be wrong...
I'd be careful of that, as the straps may dig into the spring, and it they did, then the spring most likely be seriously damaged. It may not be junk, at this point, so I'd exercise caution.
Old Apr 8, 2016 | 07:01 PM
  #35
Dave70's Avatar
Dave70
no the spring is tight against the bottom of the lower a arm. The bolt is all the way "tight" for lack of a better word. And after looking closer it is the t1 bars and end links. Not sure about the shocks. Can't find that part# listed anywhere.
Old Apr 9, 2016 | 09:30 AM
  #36
leadfoot4's Avatar
leadfoot4
Yeah, but the "hex end" at the top of the adjuster bolt, is what you turn, when you adjust the ride height. It should be protruding through the top of the spring......
Old Apr 9, 2016 | 09:53 AM
  #37
Dave70's Avatar
Dave70
The spring is under the a arm it attaches to the spring then goes through the a arm.
To lowering procedure
Old Apr 9, 2016 | 12:19 PM
  #38
leadfoot4's Avatar
leadfoot4
Are you talking front or rear??
Old Apr 9, 2016 | 01:17 PM
  #39
Dave70's Avatar
Dave70
Rear.
Old Apr 9, 2016 | 03:36 PM
  #40
leadfoot4's Avatar
leadfoot4
Rear.
OK, then. The rear uses a different method than the front, and this topic originally started out discussing the front spring.....
