The point of Coilovers is to replace the Leaf spring setup. You don't run both. I would suggest running the coil over with the springs they have on them and then stiffening from there. You can get a pretty much infinite number of spring rates from a lot of places. Also Id check to make sure those Pfadts aren't blown as from reading a lot of people had issues with those coilovers blowing.
I read that the rated spring rates of coil overs are lower because they are measured at a different location, contact Pfadt and ask them for the corrected spring rates.
