clutch
Old Apr 2, 2016 | 09:13 PM
johnfin's Avatar
johnfin
Default clutch
Is it true you have to drop the transaxle to replace the clutch and slave cylinder
Old Apr 2, 2016 | 09:50 PM
StingrayRebel's Avatar
StingrayRebel
yep, the rear suspension, differential, transmission, torque tube, and exhaust will have to come out
Old Apr 2, 2016 | 09:52 PM
johnfin's Avatar
johnfin
Default clutch
Oh that sucks
Old Apr 2, 2016 | 09:53 PM
johnfin's Avatar
johnfin
Default job
Ps can this be done with car on 4 ramps
Old Apr 2, 2016 | 10:12 PM
StingrayRebel
the front can be on ramps but you will need jack stands under the frame in the rear in order to be able to drop everything out
Old Apr 3, 2016 | 08:44 AM
helga203's Avatar
helga203
This should get you going in the right direction.http://tech.corvettecentral.com/2011...-installation/http://redshift.homestead.com/files/...ch_install.pdf
To clutch
