top-end driving question
Old Sep 4, 2002 | 04:20 PM
Red Gump's Avatar
Red Gump
Default top-end driving question
I haven't driven my car ('97 6 spd) over 120 yet and I may have the opportunity to top her out in the near future. use 6th or no? if yes, at what speed should I shift into 6th? I thought I read somewhere that you don't use 6th for a top end run. thanks! :seeya
Red
Old Sep 4, 2002 | 04:28 PM
xwing's Avatar
xwing
Default Re: top-end driving question (Red Gump)
The car reaches top speed in 5th gear. You never need to shift into 6th at all for a top end run.
Old Sep 4, 2002 | 04:39 PM
Red Gump's Avatar
Red Gump
Default Re: top-end driving question (rworkman98)
thanks! can someone explain in lay-man's terms why 6th is of no benefit in a top end run?
Old Sep 4, 2002 | 04:47 PM
MDT's Avatar
MDT
Red Gump,
6th gear is .5:1 over drive at the wheels. The gear just isn't deep enough to overcome the air resistance at the higher speed, so the engine can't pull to the maximum RPM.
Let's be careful out there. :yesnod:
Mark
Old Sep 4, 2002 | 04:52 PM
Lil Red's Avatar
Lil Red
Default Re: top-end driving question (MDT)
Excellent simple and concise explanation!
Old Sep 4, 2002 | 05:02 PM
Red Gump's Avatar
Red Gump
Mark
thank you sir! and yes, careful, careful, careful--going to have the car checked head to toe and back and drive the route several times prior (blocked off/clear stretch). I'm a big chicken though, don't know if I'll have the nerve to take her all the way.
Old Sep 4, 2002 | 06:33 PM
geocav's Avatar
geocav
Red; As Mark says, " Always be careful" but you need not worry about the car... Here in Europe where I live I cruise at 140 and have hit 165 + many a times (per week).... That is what this puppy was built for.... just make sure, as one always should do, even when you are only going 50, that the basics are taken care of.... tires, brakes, etc...
Enjoy....
George
Old Sep 4, 2002 | 06:50 PM
turboo2u's Avatar
turboo2u
Default Re: top-end driving question (geocav)
tops out at about 179 in 5th
Old Sep 4, 2002 | 07:39 PM
MiamiDave's Avatar
MiamiDave
Default Re: top-end driving question (turboo2u)
No problem reaching 150-most can do it from a stop in 1 mile. Apparently, the 150-175 takes a looonggg time.... Also, a hood seal might help the hood warble at speed.
I'm waitinf for the rest of the mods for a 150+ run (quicker to get thare and over). Also, wait till your tires have at least 10K on the tires, as continuous high speeds can screw up fresh rubber.
Old Sep 5, 2002 | 07:10 AM
Steve02C5's Avatar
Steve02C5
From: Renaissance Festival TAZ the Wolfdog (R.I.P.)
I've gone to 145mph and felt comfortable, but the driver side window sucked away from the seal and you can imagine the noise created. I then shut 'er down. How do you keep the windows sealed or do you just listen to the noise? :cheers:
Old Sep 5, 2002 | 09:28 AM
NassyVette's Avatar
NassyVette
Default Re: top-end driving question (Steve02C5)
Duct Tape. Goodluck on the run :cheers:
Old Sep 5, 2002 | 10:19 AM
gtragitt's Avatar
gtragitt
Cruise-In II Veteran
Cruise-In III Veteran
St. Jude Contributor
There isn't enough power for such high gearing. I don't know how much power would be required to reach 150 in 6th. My bone stock 2001 convertible would top out at 130 in 6th. I haven't gone above 150, but I know there was still more top end in 5th.
To top-end driving question
