Solid Plate motor mounts
Old Apr 7, 2016 | 02:58 PM
sgtskid's Avatar
sgtskid
Default Solid Plate motor mounts
Anyone have a CAD file for solid front plate motor mounts?
Old Apr 7, 2016 | 05:00 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
I hate to be nosey, but what are you building? That's a pretty extreme setup.
Old Apr 7, 2016 | 10:13 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
You mean like a motor plate for a drag car?
Bob at AEI makes them. Others do too, but I can't think of who.
ECS made a really nice one for Jay's car. I don't think they offer them anymore.
But, like the guy above me asked, what's the application?
Old Apr 7, 2016 | 10:16 PM
sgtskid's Avatar
sgtskid
I have a 1986 BMW 3 series I am dropping a 5.3L LM4 into. I want to design/fab a set of plates that will use bushings for a little dampening. Using plates vs. traditional mounts should ease some pain when trying to find headers that clear around the steering shaft.
I could buy a set of plates but I have access to a water jet and i would spend as much time modifying a set as I would designing a set from scratch.
Old Apr 7, 2016 | 10:20 PM
sgtskid's Avatar
sgtskid
Yup, like a drag car.
There are several companies that make them but with the modifications I want to make I believe I may be better off starting from scratch. I would like to find a cad file to get the block pattern correct and I can then draw the mounts for the car.
Old Apr 9, 2016 | 10:01 AM
C5 Pete's Avatar
C5 Pete
AMP Racing
Cool. Sounds like a fun project. Good luck with it.
Old Apr 11, 2016 | 04:01 PM
sgtskid's Avatar
sgtskid
Thanks!
Now to find that CAD drawing
Old Apr 11, 2016 | 04:36 PM
Smoken1's Avatar
Smoken1
You still doing the other things? I sent someone your direction
Old Apr 12, 2016 | 09:37 AM
sgtskid's Avatar
sgtskid
I am.
You have a PM.
Old May 5, 2016 | 03:35 PM
sgtskid's Avatar
sgtskid
Got it!!
Through a private PM I was able to obtain a 3d model of an LS engine. From there, I was able to draw the beginnings of my plate. The picture is the first shot which I missed the dimensions on the timing chain cover. The rendering is trial #2 which I need to print.
Old May 6, 2016 | 04:30 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
Old Jun 1, 2016 | 11:12 PM
sgtskid's Avatar
sgtskid
Now that I have the motor mocked up, it's time to get the mounts in the car drawn up. I created a rough rendering of the engine bay so I could pull the dimensions I'd need for the plate.
Old Jul 22, 2016 | 02:30 PM
sgtskid's Avatar
sgtskid
Got the final plan completed and sent the drawings to the machine shop. Got back the motor plate the other day. Fits like a glove! Fits so well that I will need to grind a little off around the TC cover to make room for the gasket. I will also need to take a little off the driver side to clear the head. All easy stuff.
Old Jul 22, 2016 | 05:15 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
Awesome! Nice work
Old Aug 12, 2016 | 03:56 PM
sgtskid's Avatar
sgtskid
From concept to reality.
First test fit of the motor and everything fit perfectly. Now I need to finish weld the motor mounts and take care of a few other details.
p.s. Mods, if this thread needs to be moved to general discussion or somewhere else more appropriate please do so. Thanks.
Old Aug 12, 2016 | 04:02 PM
feeder82's Avatar
feeder82
Old Aug 12, 2016 | 05:52 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
To Solid Plate motor mounts
Old Oct 18, 2016 | 09:59 AM
sgtskid's Avatar
sgtskid
The 1/4" plate throws the alignment off on the belts so I had to play with different accessories and measurements to get everything to line up. The final assembly includes a Corvette water pump, Corvette tensioner, F-body balancer, and the trucks original alternator. I had spacers machined to fit behind the alternator and the tensioner to bring everything into line. The trucks original accessory bolts were used on the alternator and two of the shorter bolts were further shortened to use on the tensioner.
I still need to do one final test fit in the car and tack the mounts on the plate. I'll then remove the plate and finish weld the mounts followed by a sand blasting and a coat of paint.
Old Oct 20, 2016 | 09:58 AM
nsogiba's Avatar
nsogiba
Super cool. Think that much belt wrap on the water pump will be ok?
Old Oct 20, 2016 | 12:43 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Direct drive kits have about the same amount of wrap, never an issue. Nice work OP.
