2000 C5 headlight problems
Old Apr 8, 2016 | 09:06 AM
corv2k's Avatar
corv2k
Navigator
Default 2000 C5 headlight problems
Need your advice. The headlight switch on the turn signal stopped working so I used the DIC to turn on the twilight and that worked three times.
Now the lights come on but the buckets do not pop up.
As I recall in another thread, there are two possible failures. One is the headlight switch on the turn signal stalk. What is the other item that could be causing this problem?
My car was built in December of 1999.
Thanks, corv2k
Old Apr 8, 2016 | 10:52 AM
dadaroo's Avatar
dadaroo
Could be the HL control module. Not at home now but I doubt it is a fuse issue.
Mr. Sam
Here is a link with an identical issue that is going on now in the Tech Forum.
https://www.corvetteforum.com/forums...no-noises.html
Old Apr 8, 2016 | 11:01 AM
corv2k's Avatar
corv2k
Navigator
I do not have a HL motor or gear problem... Already replaced the plastic gears with brass.This seems to be electrical.
If i replace the HL control module and the HL switch, should that fix the problem?
Old Apr 8, 2016 | 03:08 PM
runner140*'s Avatar
runner140*
I have a spare headlight control module.....purchased used last year, but didn't use it. If you are interested, PM me.
To 2000 C5 headlight problems
