Can I band clamp this?
Old Apr 8, 2016 | 07:46 PM
bwill03z's Avatar
bwill03z
Default Can I band clamp this?
Got my cats in they are 2.5" but they are slip fit so the in/out diameter is a little more than 2.5. There is a pretty good amount of play between the cat pipe and the collector reducer pipe. Will a band clamp seal this good enough?
Old Apr 8, 2016 | 08:32 PM
SG Lou's Avatar
SG Lou
Looks like the gap is a little too big to seal with just a band clamp.
Old Apr 8, 2016 | 08:36 PM
bwill03z's Avatar
bwill03z
What would you suggest?
Old Apr 8, 2016 | 09:21 PM
Rob 02's Avatar
Rob 02
Why wouldn't you weld/ have it welded?
Old Apr 8, 2016 | 09:32 PM
bwill03z's Avatar
bwill03z
That's probably what I'll end up having done. I was just hoping to be able to keep everything just bolt on.
Old Apr 8, 2016 | 09:34 PM
brplatz's Avatar
brplatz
Agreed, an exhaust shop wouldn't charge much for something like this to be done right
Old Apr 8, 2016 | 10:21 PM
That's what I would do if it were mine.
Old Apr 8, 2016 | 10:32 PM
bwill03z's Avatar
bwill03z
Thanks for the feedback guys. I'll take it and have it welded next week.
Old Apr 9, 2016 | 12:42 AM
grantv's Avatar
grantv
Bolt it together and decide for yourself. Worst case scenario you drive it with a small leak to an exhaust shop. But I also think it'll need welding.
Old Apr 9, 2016 | 01:01 AM
Rob 02's Avatar
Rob 02
You can buy a flux MIG welder at H/F for $100 and practice welding if you are into the DYI thing.
But if you go that rout you will have to spend $50 more on a mask, stainless wire and gloves.
Old Apr 9, 2016 | 02:34 AM
SG Lou's Avatar
SG Lou
Like some of the guys said......I'd take it to a Exhaust shop and have them MIG or TIG weld it on.
Old Apr 9, 2016 | 09:50 AM
dadaroo's Avatar
dadaroo
Any exhaust shop can expand your exhaust pipe so you can use a clamp.
Mr. Sam
Old Apr 9, 2016 | 10:40 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
Mr. Sam
I like a clamped system also. If you expand the smaller pipe, then the clamp should work fine.
Good luck.
Old Apr 9, 2016 | 10:53 AM
bwill03z's Avatar
bwill03z
Good luck.
Yeah I would prefer to go that route. The shop that is doing the install for me has a pipe expander so it shouldn't be a problem. I'm going out today to buy the clamps. I'm not if I need a 2.5" or 3" clamp though. The cat is prob about 2.75"
Old Apr 9, 2016 | 10:56 AM
johnson-rod's Avatar
johnson-rod
You could also cut up a beer can and make a sleeve.
It's a little 'red neck' but it sure meets the 'git'er done' rule.
Old Apr 9, 2016 | 12:18 PM
SG Lou's Avatar
SG Lou
Mr. Sam
yes they can expand the pipe but......the thickness of the cat will not "crush" or seal properly. The other thing is band clamps are made of stainless, it will not conform to the step you'll have where the thicker cat metal meets the thinner pipe. Last but not least, if i'm not mistaken, most outer diameter pipes will have a small slit on one side so the band clamp can compress the outer pipe to conform to the shape of the inner pipe.
Old Apr 9, 2016 | 12:33 PM
bwill03z's Avatar
bwill03z
There aren't any slits on the in or out of the cat. I can weld the collector reducer pipe to the input of the cat but if i have the connecting pipe(between the cat output and the xpipe input) expanded to go Over the output of the cat should I be able to band clamp that part? Sorry if that's confusing. Basically I can have 2.5 pupe expanded to slip over the output of the cat... will that clamp ok or is it the same situation of it not sealing properly?
To Can I band clamp this?
Old Apr 9, 2016 | 12:41 PM
SG Lou's Avatar
SG Lou
I know there isn't any slits...that's the point i was trying to make, no slit, no compression to help seal. 2.5",,,, I dunno if you'd have enough sealing area to get a good seal. I could be wrong.
Old Apr 10, 2016 | 12:30 AM
84REDCROSSFIRE's Avatar
84REDCROSSFIRE
I would have that welded by someone who welds stainless, bad stainless welds are brittle and a mess to cut out and do over when they crack.
Old Apr 10, 2016 | 03:09 AM
Stroker87's Avatar
Stroker87
was thinking the same thing wondering why most said to weld it then seen you posted this
removable cats
simple fix! put a notch on each side then clamp
i've had and even worked on exhaust with slip fit that didnt have the notch and still sealed with a clamp
