Don't know if you can make it out in this video but it appears there is a wobble in the balancer. How much is too much? Can I drive the car safely and without damage to the engine the way it is?
I think the bigger concern is... has the inner and outer ring separated? You can take some white paint and put a stripe across them and keep an eye on it to see if there is any movement...also I would check to see if the HB has moved on the crank snout... out and it will start rubbing on the steering rack... if, it moves in it will wear on the timing cover, either one is NOT good. Having said that, I have kept an eye on our HB that has a similar wobble for several thousand miles and see no sign of it getting any worse or moving... IF and WHEN I do I will change it.
OR if I get really bored next winter I may do it.
It's just a matter of time once it starts wobbling before it has to be replaced. Start saving for the repair and plan to have it done before it gets much worse. If you have the time and a place to work, the job is very doable by anyone that isn't afraid to tackle it. There is plenty of information here about how it's done.
My '97 had a very similar issue and was wobbling like yours. A new balancer, bolt, power steering fluid, and a few rental tools was less than $150 to get this fixed. It took me about 8 hours from start to finish, and I also bled the power steering system while I was at it. The difference is night and day, and the car drives a lot smoother.
Here are some pictures of my old balancer so you can see just how bad it was.
The way to tell is watch the belt grooves. They should run true with no front to back movement at all.
Sure, you can drive it the way it is right now without any damage to the car. But, I wouldn't be doing any drives that were much distance at all without a roadside assistance plan or willingness to pay for a flat bed. When it does let go and the outer ring starts to slip things generally go downhill very quickly. A complete failure isn't something that you can limp home or to a repair shop. The outer ring will quickly move forwards or rearwards and start to rub and the misalignment this causes generally throws or sheds the belts.
If the outer ring moves forward it hits the steering rack. If it moves backward it hits the timing cover. (That's what happened to me.) Removing the timing cover and resealing at the oil pan is a lot more work.
Mine did this. Threw the belt off while driving. Careful with it though, if the balancer pushes out you're safe if it pushes in you risk some damage. Replace it with an ATI under drive pulley and an ARP crank pulley bolt! I went with the 10% under drive but I wish I would have done the 25%
Most people use the ATI pulley from what I have seen. We used the Summit Racing pulley and the ARP bolt.
Interesting comment. I wish I'd done the 10% under-drive instead of the 25% under-drive. My car won't maintain battery voltage in stop and go traffic on a hot day with the AC cranked. The battery voltage ever so slowly drops off.
When you replace the balancer do yourself a favor and go with something beside the AC Delco replacement.
I rebuilt my engine in May 0f 2015 and replaced the balancer with a brand new AC Delco. I just finished replacing that 3000 mile pile of junk due to extreme wobbling and belt chirp that started after 2000 miles on the new engine.
I went with the Power Bond OEM Replacement part #PB1117N. It was $78.00 with free shipping.
I also went with the ARP Crank bolt. It just uses a torque spec. instead of the angle tightening ordeal.
