1999 FRC AC issue
Old Apr 14, 2016 | 04:15 PM
huntersdad14's Avatar
huntersdad14
Default 1999 FRC AC issue
Hello, I just bought a 1999 FRC 2 days ago. AC was freezing cold and I had to use the defrost on windshield. When I turned the air from cold to hot the air now blows HOT no matter what I do. Pressed and depressed the AC button hasn't helped. Any help would be great appreciated. Thanks oh, car had 112XXX miles and runs like a top otherwise.
Old Apr 14, 2016 | 04:43 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
good place to start ck for codes !!
Old Apr 15, 2016 | 01:25 PM
huntersdad14
Well.... I'm as confused as ever... didn't use the AC yesterday (or attempted to turn it on) and turned it on this afternoon and it works perfectly. .. I guess giving her a name at lunch helped... DAMNIFIKNOW!
Old Apr 16, 2016 | 01:10 AM
BigGun's Avatar
BigGun
That can happen when an actuator doesn't function properly. There are many possible causes. If this happened there is likely a history code set. You have to use the dic to see these type of codes. The code will be set in the hvac section. If there is a code set for the actuator just clear it and hope it doesn't return.
Old Apr 16, 2016 | 03:42 PM
huntersdad14
Thanks for the info everyone. I do appreciate it.
To 1999 FRC AC issue
