2001 Automatic Transmission issue
Old Apr 15, 2016 | 02:14 PM
FullSpool's Avatar
FullSpool
7th Gear
Default 2001 Automatic Transmission issue
Hello guys,
I just picked up a project car with known issues, before I take it to the garage I was wondering if I could get some opinions on what the issue might exactly be.
History of the car:
The engine has been replaced , engine is around 156k mark
Transmission has been rebuilt
Rear end was rebuilt
New transmission cable
There are receipts to validate the claims but I have no idea what the actual work completed was as I have no itemized bill but the car still has issues.
When driving normal the car drives and shifts fine. You can gradually
press the accelerator and it will shift through all 4 gears. However if you are going around 45 mph and just punch the accelerator it will bang off the rev limiter and will not shift unless you back off the pedal and gradually push it down. It does the same thing with traction control on and off.
There is also a clicking noise coming from the right rear wheel, you can hear it click when backing up and moving forward. The clicking sound gets faster (not louder ) as you accelerate.
Do you guys have any ideas? I'm mechanically inclined but this is my first corvette.
Thanks for your time,
Full Spool
Old Apr 15, 2016 | 03:18 PM
enoniam's Avatar
enoniam
Are you saying that it doesn't downshift at 45, slips and hits the rev limiter, or that it does downshift but doesn't upshift and hits the rev limiter?
Old Apr 15, 2016 | 03:25 PM
FullSpool's Avatar
FullSpool
7th Gear
I can't feel it downshifting , of course there's alot going on in those few seconds . It seems like it goes into neutral, bangs the Rev limiter. I let out and drive it normal. I still need to test it more but that's the best I can describe it until I get the power steering line fix so I can post a video.
Old Apr 15, 2016 | 03:29 PM
enoniam's Avatar
enoniam
If it isn't downshifting then it's probably slipping 3-4 clutches or the band.
If it is downshifting I would suspect that when the rear end was rebuilt the ratio was changed and the computer tune wasn't properly updated for when to shift (rpm and vehicle speed) at WOT.
Where are you located?
Old Apr 15, 2016 | 03:35 PM
FullSpool's Avatar
FullSpool
7th Gear
I am in kentucky
Old Apr 15, 2016 | 03:39 PM
enoniam's Avatar
enoniam
Hmmmm - depending upon where in KY I'm only a couple of hours away and it's going to be a beautiful weekend to get the car out.
I'm near Bloomington, Indiana. What part of KY are you in?
Old Apr 15, 2016 | 03:47 PM
FullSpool's Avatar
FullSpool
7th Gear
I am close to bowling Green , actually glasgow. So that's probably a 4 trip I would guess .
Old Apr 15, 2016 | 03:59 PM
enoniam's Avatar
enoniam
Well, the way I drive, I'm a bit under 3 hours to Bowling Green, so probably about 3.5 to Glasgow.
I haven't been to the museum since the hole was fixed....
I'd like to put my HPTuners scanner on your car and see what the computer is doing and sees.
We were probably going to put the top down on the vette and go cruising Sunday or Saturday anyway...
If you'd like to have me take a look I can see what the wife thinks about a 6 hour cruise...
Why am I suddenly thinking about Gilligan's Island???
It's not like we haven't driven down there just for the heck of it before!
Old Apr 15, 2016 | 04:36 PM
FullSpool's Avatar
FullSpool
7th Gear
Haha if your wife's name is Mary Ann then that would be even funnier . If you wanna come down I would be honored by your generosity The car will be on the lift tonight as I'm gonna start going through it and get the high pressure power steering line fixed tonight.
Old Apr 15, 2016 | 05:08 PM
enoniam's Avatar
enoniam
No Mary Ann here, LOL!
I'll see what plans she's got and let you know.
Old Apr 15, 2016 | 07:22 PM
Smoken1's Avatar
Smoken1
Ginger maybe?
Old Apr 15, 2016 | 10:05 PM
enoniam's Avatar
enoniam
Sent you a pm Fullspool.
Old Apr 15, 2016 | 10:38 PM
thumpinc5's Avatar
thumpinc5
Check it for codes. See if one is present for the 3-2 downshift solenoid. We see this complain quite often when the wrong year transmission is installed, but that's not very likely in your C5, unless someone has swapped the valve body. If it's cutting loose on the 2-3 shift at heavier throttle, it could very well be the 3-4 clutches. They were a fragile area in the stock 4L60Es. We have to correct no less than 6 different "design flaws" in them just dedicated to the 3-4 clutches.
Frank
Old Apr 16, 2016 | 10:31 PM
FullSpool's Avatar
FullSpool
7th Gear
Worked on it some more today, first 2 pulls I did today it didn't hardly missed a beat. Slight slip between 3 to 4 .
As I continued testing 3 and 4 pull banged off the rev limiter again , all these pulls were from 40 to 75 mph.
The noise I heard from the right rear wheel is actually a clicking noise in the transmission. It doesn't get any louder only gets faster as Rpms increase .
I have an O2 code and some abs errors. Also the dash light shows the traction control light (amber color ) on . It doesn't matter if you turn the button on or off it stays illumated.
Old Apr 16, 2016 | 11:53 PM
BigGun's Avatar
BigGun
At what rpm do you hit the rev limiter? Here's is a link that describes how to pull the codes. Need to know the codes to help you out.
http://www.stengel.net/diccodes.htm
Old Apr 20, 2016 | 04:56 PM
enoniam's Avatar
enoniam
HPTuners confirmed the PCM was commanding a downshift into 2nd and after some banging off of the rev limiter the tranny settled down and started pulling through the 2nd gear WOT rev range. Line pressure solenoid current was reduced during this period as expected. We noted that a 3rd-1st downshift operated as expected.
I agree thumpinc5 that there may be an issue with the 3-2 solenoid. To me it seems as if the band is taking a while to firmly engage but when it does all seems well.
Old Apr 20, 2016 | 11:31 PM
FullSpool's Avatar
FullSpool
7th Gear
Thanks for all the help Greg , I appreciate you taking time to help me out . Hope you and your wife enjoyed the drive . I still havent made it to the transmission shop , once work allows me to leave at a reasonable time during the week it's my first stop ! I've been looking at the diagrams and I don't know if I'm confident enough to tear it apart just yet, hopefully after the shop visit I will feel a little better about it. I've been driving it daily so it hasn't got any worse.
Here are the list of codes so far :
C1225 front wheel excessive wheel speed variation history
C1287 steering sensor rate history
C1288 steering sensor circuit
P1133 heated oxygen sensor
I also have the service traction control warning message across the dash.
Old Apr 24, 2016 | 12:30 AM
C5stroker's Avatar
C5stroker
Mine did the same thing today. But I stretched my tranny cable. And the car thinks it's in 3Rd when I put it in drive. Banged off 6500 when it down shifted when I matted it at 60. You may have screwed your tranny cable. My car will shift normally then at wot see that the car is set in 3rd. Preventing an overdrive feature.
To 2001 Automatic Transmission issue
