Need Help With Interior Lights
Old Apr 15, 2016 | 05:24 PM
RogerT's Avatar
RogerT
Default Need Help With Interior Lights
The interior lights in my 2004 C5 stopped working. A bad fuse sounds logical.Found no listing for "interior lights". Where do I start?
Thank for your help.
RogerT
Old Apr 15, 2016 | 10:10 PM
brazilianvette's Avatar
brazilianvette
I had a burned fuse when mine stopped working. I believe the fuse was located in the floorboard, passenger side under the carpet. You can try that?
Old Apr 15, 2016 | 10:43 PM
RogerT's Avatar
RogerT
Default Fuse ID
How is the fuse identified? Is it a fuse , a mini relay, a micro relay? There is a micro "courtesy" relay.
RogerT
Old Apr 16, 2016 | 07:08 AM
LWSZ06's Avatar
LWSZ06
RogerT
Here are some schematics of the interior lighting:
Larry
Old Apr 16, 2016 | 07:57 AM
dadaroo's Avatar
dadaroo
RogerT
It would help to know if EVERY light inside is out or if it is a specific set of lights that are out.
Mr. Sam
Old Apr 16, 2016 | 12:24 PM
SPEED750's Avatar
SPEED750
I would start with the switches.
Old Apr 16, 2016 | 08:37 PM
RogerT's Avatar
RogerT
Default Interior Lights
RogerT
All the interior cabin lights are not working.
The problem is something in common to all the lights.
RogerT
Old Apr 18, 2016 | 06:34 PM
dadaroo's Avatar
dadaroo
Are you saying the door switches are not lighting up?
Mr. Sam
Old Apr 19, 2016 | 03:24 PM
RogerT's Avatar
RogerT
I have found the problem. In the fuse/relay box located under the passenger side toe pan are a number of relays and fuses, the fuse foe the interior lights is no. 29, a 10a fuse. it is located on the right side second row in from the right 1/2way up from the bottom. It is just above the third relay from the bottom.
Thanks for the help.
RogerT
Old Apr 20, 2016 | 05:44 AM
dadaroo's Avatar
dadaroo
That fuse does not cover all the interior lighting.
Mr. Sam
Old Apr 22, 2016 | 09:25 PM
brazilianvette
What controls the timer? A relay? If so, which one is it? My interior/mirror lights seem to stay on longer than what would be reasonably normal. Thanks.
Old Apr 23, 2016 | 08:32 AM
dadaroo's Avatar
dadaroo
The BCM controls dimming.
Mr. Sam
Old Apr 23, 2016 | 11:14 AM
helga203's Avatar
helga203
[QUOTE=dadaroo;1592037469]That fuse does not cover all the interior lighting.
Mr. Sam[/QUOTE I'm in not reading the schematic right?? Doesn't it show fuse 29 protect all the interior lights??? Confused. Help me understand this. Thank you.
Old Apr 24, 2016 | 06:49 AM
dadaroo's Avatar
dadaroo
Fuse 29 does not power all interior lights. How about the doors, HVAC, Radio, IPC, DIC?
People post without thinking what they are actually saying.
Mr. Sam
Old Apr 24, 2016 | 09:14 AM
helga203's Avatar
helga203
Mr. Sam
Got it. I was just thinking of the lights under the dash as the only interior light. My bad.
Old Apr 24, 2016 | 09:30 AM
dadaroo's Avatar
dadaroo
My comment was not about you.
Mr. Sam
To Need Help With Interior Lights
