steering column look problems
Old Apr 16, 2016 | 07:12 PM
Greg Gould's Avatar
Greg Gould
4th Gear
Default steering column look problems
i bought a 97 automatic about four months ago . when i would pull my key the key chime would keep chiming.this has been going on for about a month.just the other day i got a error code pull key and wait 10 seconds and car would not start. i had the car towed home and when they unloaded it ,it started and ran fine.now it has done it again. the column wont lock so they have done the recall fix. i have ordered the lock bypass.i have read all the threads and am having trouble making head or tails. is this fix going to help , will i have to unhook what they did ?please help me if you can
Old Apr 16, 2016 | 07:14 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
you need this !!!!
http://www.complianceparts.com/lmc5whoneeds1.html
Old Apr 16, 2016 | 08:04 PM
Greg Gould's Avatar
Greg Gould
4th Gear
Originally Posted by akapounder
will this work the way it should even if the recall has been done
Old Apr 16, 2016 | 08:10 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
of the 4 recalls none of them fixed it !!!!!!!!!!! This did !!!done deal !!!!!
Old Apr 16, 2016 | 08:13 PM
Greg Gould's Avatar
Greg Gould
4th Gear
i wont need to change or remove anything they did
Old Apr 16, 2016 | 08:16 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
No !!! if you need reinsurance call the number (LMC5) and talk to Richard !!!!
Old Apr 16, 2016 | 08:33 PM
73Corvette's Avatar
73Corvette
what pounder said...
Old Apr 16, 2016 | 10:05 PM
Greg Gould's Avatar
Greg Gould
4th Gear
thanks for your help
Old Apr 17, 2016 | 12:11 AM
BigGun's Avatar
BigGun
How is your battery? You should have it checked. A low battery can cause the problems you are experiencing. The column lock will not keep the car from starting. You need to pull and post the codes.
http://www.stengel.net/diccodes.htm
Old Apr 17, 2016 | 06:48 PM
huesmann's Avatar
huesmann
I think the word you're looking for is "reassurance" LOL.
Old Apr 17, 2016 | 06:52 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
I am a victim of auto correct or lack there of
To steering column look problems
