window / lock problems
Old Apr 16, 2016 | 09:52 PM
Hoosierdaddy57's Avatar
Hoosierdaddy57
7th Gear
Default window / lock problems
Last fall the passenger window on my 2000 c5 refused to close. Thinking the motor was malfunctioning I tapped on the mounting bolt with a hammer and it worked again repeatedly. I figured this may be to the window not being exercised much since new. This week the problem returned. Additionally the power lock will not lock the door. If I manually lock the door it will unlock with the power. We are 300 miles from home and the window is up so I'm leaving it alone til I get home. My question is: Is there a common component I should address that would cause both the window to not go down and the power lock to not function.
I'm loving my new to me c5!!!
Old Apr 17, 2016 | 09:08 AM
dadaroo's Avatar
dadaroo
Need more info. Where were you trying to operate the passenger door? From the drivers side or passenger side?
Mr. Sam
Old Apr 17, 2016 | 10:12 AM
Hoosierdaddy57
7th Gear
Neither the key fob, or either door button will lock the passenger door but they will unlock it.
Old Apr 17, 2016 | 10:26 AM
dadaroo's Avatar
dadaroo
That sounds like the RDCM relay for lock is the problem. Common issue and can be replaced for a few dollars. I provide the info on that here.
https://www.corvetteforum.com/forums...post1587396862
The bottom relay on the left in the picture is the lock relay.
If you want a vendor to fix it let me know.
Let me know if you want to discuss the window issue.
Mr. Sam
Old Apr 17, 2016 | 08:58 PM
Hoosierdaddy57
7th Gear
Thanks for the help Mr.Sam!
After returning home I was able to do more trouble shooting. It seemed that if I held the button down for a few seconds the lock would work. After a few minutes of cycling it seems to work ok. The window , however, cannot be coaxed at all. I'm thinking if I check for voltage to the motor that should indicate if it is the relay or the motor. Is there anything else I should be checking?
Old Apr 18, 2016 | 06:58 AM
dadaroo's Avatar
dadaroo
Window issue may be motor or regulator. You will just need to get into the door. Need any info on doing that?
Mr. Sam
Old Apr 18, 2016 | 09:02 AM
Hoosierdaddy57
7th Gear
I think I can get into door...It will be a few days. I have to get some business done now that I'm back home!!!
To window / lock problems
