Help Oil Cap stuck
Old Apr 19, 2016 | 12:53 AM
SaxyVette's Avatar
SaxyVette
Default Help Oil Cap stuck
Tried to add some oil but the cap seems stuck. I don't want to break anything:rofl :
Old Apr 19, 2016 | 02:15 AM
Johnny wangwang's Avatar
Johnny wangwang
If its like my 02 then you can just remove the fill neck from the valve cover. Its just held in by an O ring.
Old Apr 19, 2016 | 04:42 AM
SaxyVette's Avatar
SaxyVette
Not sure what to do. The cap turns but hits the stop and won't pull off. Seems I've had it off before, this sucks I can't add oil. Guess i'll take it to my mech.
Old Apr 19, 2016 | 06:44 AM
runner140*'s Avatar
runner140*
Went thru something similar with mine. While twisting (back and forth), keep pulling up.....it works.
Old Apr 19, 2016 | 07:26 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
then I put a little grease the threads and collar !!!!
Old Apr 19, 2016 | 01:30 PM
SaxyVette's Avatar
SaxyVette
OK it takes some wigglin' and jigglin' but it will come off. There is a small tab built into the neck, the tab engages a slot when you turn the cap. the cap will come off slick a couple times.. and then either jam or stick and won't come off without some finessing . At least I now the trick. Thanks all for the input.
Old Apr 20, 2016 | 07:40 AM
strand rider's Avatar
strand rider
I am glad you didn't have to take it to the shop . As also one with a low skill set in corvette repair, the journey of a thousand miles begins with a single step of removing a stuck oil cap.
Old Apr 20, 2016 | 07:51 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Old Apr 20, 2016 | 04:38 PM
SaxyVette's Avatar
SaxyVette
Yr ago when I did a cam replace while the motor was apart my orig cap was swiped for another car. This cap is a plain black replacement. Might be the reason it doesn't work quite right.
Old Dec 1, 2022 | 12:54 PM
04Vette-man's Avatar
04Vette-man
1st Gear
Default Just now happened
So I see this has been answered. But it just happened to me. Thus my joining in the discussion just in case a newbie has the same issue. Hopefully I can post a pic. I too had trouble. I turned the cap ccw about a quarter turn and it stopped. Tried it again. Something. Finally I twisted a bit harder and it went a little more and then it raised upwards. So it is NOT threaded on my '04. And it has an O ring. However why it stopped too soon I don't know but keep at it. Once you get it then pull straight up.
Old Oct 28, 2023 | 05:39 PM
UNODAT808's Avatar
UNODAT808
1st Gear
It worked like a charm!!! Turn and lift at the same time pop it came off!!
To Help Oil Cap stuck
