TICK MS INSTALL question?
Old Apr 20, 2016 | 08:38 PM
magnoman's Avatar
magnoman
Default TICK MS INSTALL question?
Hey guys,
Doing a Tick MS install almost done . what PIA to get clutch line apart and back together with headers ....
Noticed a white switch at top of clutch pedal that know with Tick MS pedal does not come back as far anymore to make contact with the switch .
What is that switch for . Neutral safety ?
Old Apr 20, 2016 | 09:49 PM
StingrayRebel's Avatar
StingrayRebel
I believe it's for cruise control, the neutral safety switch is at the bottom of the clutch pedal... you should be able to screw it in or out as needed until it makes contact... if it is screwed in all the way and still not contacting the pedal then most likely you have the pedal set too low to begin with, I haven't seen a car with a properly adjusted tick master that sat that low to the floor
Old Apr 21, 2016 | 07:50 AM
3sACROWD's Avatar
3sACROWD
It is the cruise control switch. I have the same issue. I followed the install instructions and my pedal is no where near the switch. I used zip ties to close the switch for now. The car doesn't seem to like it because I now get code 0704 once-in-awhile.
To TICK MS INSTALL question?
