Ignition Relay Question
Old May 8, 2016 | 07:39 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
Default Ignition Relay Question
Every once in awhile I go start the car nothing happens,I replace the ignition relay under the hood and it starts right up,Anybody ever have this problem? Can I get a heavy duty relay and make it work some how or bypass the relay with an on off switch and heavy duty relay,Where you can turn the switch on,start the car and turn the switch off
Old May 8, 2016 | 09:55 PM
fasttoney's Avatar
fasttoney
Try bill curlee ignitin switch repair. By removing the relay, you may just be resetting the ignition switch. Or you can have a bad relay. Try swapping with another one in the fuse box.
