Working on a 2003
Passenger side door lock wont function with either button or
key fob.. Everything else works fine..
So I replaced the lock actuator/latch assembly.
Still NOT Working..
Do you think it's the module ??? Part # is 09389699 which is discontinued. Have to buy both left and right to match from GM which
is over $1200
Any suggestion welcome
The module does "click" when using the lock buttons.. just doesn't activate the actuator
