HVAC passenger actuator question...
Old May 22, 2016 | 06:29 AM
m3456y's Avatar
m3456y
Navigator
Default HVAC passenger actuator question...
I've read a number of posts on this issue, but I'm hoping a C5 pro can help me with my situation.
History: 1998 Corvette and about 6 months ago, I was getting a/c from drivers side and hot air from passenger side vents. I followed the re-set procedure for the actuator and that seemed to fix it.
The climate control display slowly got dimmer until it could no longer be seen. I took the console apart, pulled the control and re-soldered the resistors. After re-assembling, the display was bright again, the drivers side was ice cold, but the passenger side was now hot. I tried the re-set procedure 3-4 times, disconnected the battery for 15 minutes, checked and added a little freon and the car is still blowing hot from the passenger side vent. I pulled the codes, after clearing them once and got B0365, B0367, and B0446 which all point to a bad passenger actuator - or something in the circuit.
Here's my dilemma: Is the issue related to re-soldering the resistors in the control module, or is it in fact a bad actuator. If it's the module, it's a lot easier to pull that and re-solder vs. pulling the dash to change the actuator. If it's module related, it would be great to know which resistor might be the culprit (I have the circuit board with resistors in a line, and 3 others together). If not the module, does anyone have the actuator upgrade part number?
Thanks in advance...this is making me crazy!
Old May 22, 2016 | 07:04 AM
tbrowne's Avatar
tbrowne
Sounds like the passengers side actuator is bad. The link below might help if you haven't already seen it.
https://www.corvetteforum.com/forums...actuators.html
Old May 22, 2016 | 07:53 AM
dadaroo's Avatar
dadaroo
I do not think it is the HVAC unit but that the actuator is the problem. Do you need DIY info for pulling the dash pad?
Mr. Sam
Old May 22, 2016 | 01:09 PM
m3456y's Avatar
m3456y
Navigator
Mr. Sam
Update: I found another thread on this issue on a C5 forum. The problem was fixed by turning off the A/C, then disconnecting the battery for 5 minutes. When I connected it, everything worked as normal. I had tried disconnecting the battery before, but I never tried it with the A/C off.
To HVAC passenger actuator question...
