SWPS part# question
Old May 23, 2016 | 02:37 PM
not2old's Avatar
not2old
Default SWPS part# question
I have a 2002 base vert with tilt/tele column. From searching every thread I can find on here it seems I need part# 88965543. My concern is gmpartsdirect and gmpartshouse both have the following on the description.
Part Notes:
W/O TELESCOPING COLUMN
Will it fit?
Thanks in advance.
Old May 23, 2016 | 10:49 PM
coia96vette's Avatar
coia96vette
That is the part that I used on my '04 with telescoping column with no problem. I believe it will work fine with either.
Old May 23, 2016 | 10:54 PM
LoneStarFRC's Avatar
LoneStarFRC
Same either way:
Item 62:
62 88965543 SENSOR STRG WHL POSN Y 1 01-04 $120.25 $79.07
GM 88965543 $79.07
Item 32:
32 88965543 SENSOR STRG WHL POSN Y 1 01-04 $120.25 $79.07
Btw, gmpdirect will screw you on shipping/"handling".
HTH
Old May 23, 2016 | 11:06 PM
not2old's Avatar
not2old
Default Thanks!
Thanks coia96vette and LoneStarFRC on both points!
To SWPS part# question
