No yellow led on AC
Old May 24, 2016 | 08:39 PM
Steel dragon's Avatar
Steel dragon
Default No yellow led on AC
The yellow led has stopped coming on under the AC button on my 2000 C5 with climate control. Everything still seems to work normally. AC is cold. No codes. Bad led? If so anybody got an extra? These things definitely have a mind of their own. Thanks.
Old May 24, 2016 | 09:17 PM
tbrowne's Avatar
tbrowne
I don't think it's an LED - they weren't in common use when the C5's were built. It's an incandescent bulb soldered to the circuit board on the HVAC controller. Should be an easy replacement for someone with soldering skills. There are posts on HVAC repair on the forum that explain how to remove the controller.
Old May 24, 2016 | 09:48 PM
Steel dragon
About six months ago I put all LEDs on the pc board and the yellow lights really appeared to be LEDs. Either way it still doesn't work. Wish there was an easier way to check without taking dash apart. Again. Anybody? Thanks
Old May 25, 2016 | 08:53 AM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
It's a bad bulb. I have one burned out under the "Auto" button. When I get the time, I'm going to bite the bullet and pull the controller out and fix it. I dread it.
Old May 25, 2016 | 08:58 AM
Macleod52's Avatar
Macleod52
The bulb under my auto button failed as well. I am going to replace all bulbs with LED's in the winter I think.
Old May 25, 2016 | 10:19 AM
Steel dragon
ðŸ‘ðŸ‘ðŸ‘
Old May 25, 2016 | 10:20 AM
Steel dragon
That was supposed to be three thumbs up.
To No yellow led on AC
