Starter Problem?
Old May 25, 2016 | 06:09 PM
theheat's Avatar
theheat
St. Jude Donor '12, '14, '17
Default Starter Problem?
Hello all. Have a 2002 stock coupe. Two or three times in the last several months I'd go to start the car and only get a click. Turn the key off and try it again and it starts right up. Good battery and tight connections. Didn't check the starter connections. Parked the car today after a ride and a strange whirring and clicking sound came from under the hood after I turned the car off. It lasted for maybe 5 seconds. Started the car again, turned it off and the same thing happened. Went through 3 more starting cycles but the sound didn't return. Sounds to me like the starter pinion gear is partially engaged with the starter ring gear. Thanks for any help in advance
Old May 25, 2016 | 06:22 PM
old stingray's Avatar
old stingray
Sounds to me like your on the right track. I just went through the same problem,mine made a chattering sound under acceleration,turned out to be a broken starter bendix(pinion gear)spring. Good luck
Old May 25, 2016 | 06:29 PM
73Corvette's Avatar
73Corvette
You should do that...and batter voltage.
IF you have HEADERS they are really hard on starters... HEAT
Old May 25, 2016 | 08:32 PM
theheat's Avatar
theheat
Thanks for the help guys. Any recommendations on starters?
Old May 25, 2016 | 08:37 PM
twokbolt's Avatar
twokbolt
This one is supposed to be pretty good:
Amazon.com: Bosch SR8581N New Starter: Automotive Amazon.com: Bosch SR8581N New Starter: Automotive
Old May 25, 2016 | 08:38 PM
73Corvette's Avatar
73Corvette
Get your OEM one rebuilt... if you get aftermarket get the one that you can use the LONGER bolt with
Old May 25, 2016 | 08:53 PM
StingrayRebel's Avatar
StingrayRebel
I recommend that one as well
Old May 25, 2016 | 11:42 PM
lionelhutz's Avatar
lionelhutz
My starter started to click sometimes. I cleaned the connections and it still did it. At that point I was pretty sure it was the starter itself so I replaced it. I had to pull the header to replace the AC compressor so it was good timing.
Uses 2 longer bolts which is less likely to break and it should come with the longer bolt.
Old May 26, 2016 | 05:00 AM
Rob 02's Avatar
Rob 02
DSCF0088-1.jpg.html
Old May 26, 2016 | 06:12 AM
ZigZag's Avatar
ZigZag
I just got this one yesterday and installing it tomorrow. I also got this wrap as a precautionary measure, I have headers.
Amazon.com: DEI 010402 Versa Shield 7" x 24" Heat Wrap: Automotive Amazon.com: DEI 010402 Versa Shield 7" x 24" Heat Wrap: Automotive
Old May 26, 2016 | 07:15 AM
theheat's Avatar
theheat
Thanks for all the info guys. No headers so it shouldn't be so bad. Ordering a new starter today. will update as soon as i'm finished with the install.
Old May 26, 2016 | 09:59 AM
pmr2000's Avatar
pmr2000
Not to highjack but how are the original starter and alternators on C5's?
Do they last the life of the car? I am assuming mine are original....
Old May 26, 2016 | 01:27 PM
73Corvette's Avatar
73Corvette
They last until they quit... headers probably get quite a few starters
Excessive heat in the engine bay may contribute to alternator failures as would poor connections, bad grounds, etc... anything that causes heat...but, no need to worry about them or change them unless your having issues
Old May 26, 2016 | 01:33 PM
StingrayRebel
my oem starter was good up until the time I changed it, I just swapped it out while I was doing my clutch since I was right there and I have seen enough horror stories of the starter taking an ear off the block that I didn't want to risk it happening, and for a little over $100 it was a no brainer for me... if you ever do headers I strongly recommend having them ceramic coated, it really helps keep temps down in the engine bay and can help extend the life of surrounding parts by not transferring so much heat to them... I would also cover the wires going to the starter with some heat barrier while you're there, thermo-tec makes some really good stuff in my opinion
To Starter Problem?
