drive train rebuild. list missing anything?
Old May 29, 2016 | 11:39 AM
Jason913's Avatar
Jason913
Default drive train rebuild. list missing anything?
About to install a bunch of drive train stuff in the z, sometime in the next few weeks.
While i am doing tq tube rebuild, new clutch, slave, master etc etc etc... what else should i do while it's all out??
so far:
engine mounts
pilot
flywheel
clutch
slave
clutch master TICK
flywheel and pp bolts ARP
tq tube bearings
3" driveshaft dss
solid couplers
ecs brace
pfadt diff mount
fluids
should i do rear main seal and rear cover gasket too? anything else im missing?
Old May 30, 2016 | 12:00 AM
dork's Avatar
dork
Throw-out bearing and a clutch bleeder
Old May 30, 2016 | 12:01 AM
Jason913's Avatar
Jason913
slave / tob is all together from GM.
and you are right forgot the bleeder on my list.
Old May 31, 2016 | 09:33 AM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Any particular reason you're installing solid bushings in the TT? How much power do you make?
IMHO, they do more harm than good. And they're certainly not needed for pretty much any application under a 2000 hp drag car.
Otherwise, your list looks good. If the rear seal is dry, leave it alone.
Old May 31, 2016 | 11:59 AM
LoneStarFRC's Avatar
LoneStarFRC
I couldn't agree more on the couplers.
The 3" DSS shaft is a good choice, but stick with the GM couplers (NOT Dorman or BMW)
GM part # 88894026 Recommend either replacing all 12 coupler bolts (88894027) or really cleaning the old ones with wire brush and acetone, which dissolves the old Loc-Tite. A thread chaser (M12x1.75) to clean the female threads in any case as well.
HTH
Old May 31, 2016 | 05:03 PM
SaberD's Avatar
SaberD
here's a thread I made on my rebuild. You might get some ideas here.
https://www.corvetteforum.com/forums...dies-pics.html
Old May 31, 2016 | 08:18 PM
Jason913's Avatar
Jason913
appreciate the help guys.
I have the dss poly coupler going on the front and a solid aluminum going on the rear. Variations of this setup have been run successfully by people below, at and above my power lvl. I'd rather break axles or rear end parts, to be honest.
Old May 31, 2016 | 08:20 PM
Jason913's Avatar
Jason913
awesome link saber. you did a lot more stuff than i am about to lol.
To drive train rebuild. list missing anything?
