Cultrag-- help!!!!
Old Jun 7, 2016 | 05:40 PM
David Shiel's Avatar
David Shiel
Default Cultrag-- help!!!!
Based upon the prompt and very helpful input from others below, I am just going to flip the bar. I was looking at the old one this AM and see how we could have put the new one in upside down. Thanks all. Will let you know the outcome.
Dave
Ok, I went out this AM and jacked her up, and then flipped the bar around and it fit perfectly. No issues. Patrick from Cultrag called me this AM. I told him you guys had set me straight, but that they may want to post a caution since I am not the only red-faced customer who reversed the front Z51 bar. I am now even more humble than my former state of age-induced humility; the realization one always has a lot to learn! Can't thank you fellows enough for sharing your knowledge and experiences.
Dave
Front c6-Z51 bar not fitting correctly. front sitting 1.5 inches higher and groans on a bump. Poor clearance upon install.Hits fan motor and aluminium on both sides. Afraid to drive it.It is not the end links for sure. Could bar be bent wrong?
Dave
Old Jun 7, 2016 | 05:51 PM
My Vette Life's Avatar
My Vette Life
Originally Posted by David Shiel
Front c6-Z51 bar not fitting correctly. front sitting 1.5 inch higher and groan son bump. Poor clearance upon install.Hits fan motor and aluminium on both sides. Afraid to drive it.It is not the endlinks for sure. Could bar be bent wrong?
Dave
I am positive you installed it upside down. I did the same and thought the shocks were wasted. Looked like a truck.
Please post pics and I'll confirm.
Old Jun 7, 2016 | 05:53 PM
Smoken1's Avatar
Smoken1
Yep same thought as I had
Old Jun 7, 2016 | 06:25 PM
My Vette Life
Dave
Here's what it should look like after you install it. Notice the sway bar end link position. If it looks different than what you have, then it's upside down.
Trust me I had the same problem and took hours to figure out> I wasn't thinking and finally looked back on the video I was making for reference.
Installed correctly, the bar will not his the fan.
Old Jun 7, 2016 | 07:16 PM
David Shiel
Default If we put it in upside down
we are a bit humiliated. We could not see how to reverse it My bar does not seem to bent like the one in the pic above, but I am going to tackle it tomorrow following your diagnosis.
Anyway , I really over did it in the 92-degree heat here in Charleston and ended up with heat exhaustion. Did not hydrate as I should have. I have been banned from the garage until tomorrow by the general and ordered to drink ( beer for me) and rest!
Thanks Again,
Dave
I appreciate very much appreciate the responses from you guys!!
Old Jun 7, 2016 | 07:22 PM
My Vette Life
Thanks Again,
Dave
Old Jun 8, 2016 | 03:09 PM
David Shiel
Sure was! See my update! Thanks !
Dave
Old Jun 8, 2016 | 03:15 PM
73Corvette's Avatar
73Corvette
Glad you figured it out....thanks for posting your mistake so others can learn... we ALL make them
Old Jun 8, 2016 | 03:21 PM
Smoken1's Avatar
Smoken1
Cool glad you got it fixed!
Old Jun 8, 2016 | 03:29 PM
Rob 02's Avatar
Rob 02
LOL David. Thank you for being humble enough to post this.
I am in process of putting my suspension together and I may have had a 50/50% chance of doing this.
I will bet this thread helps others.
Old Jun 8, 2016 | 03:30 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Dave
You have had a rough couple of weeks
Old Jun 8, 2016 | 06:07 PM
My Vette Life
I know I'm a little late and was working on this all last night.
Here's a video I did with an install and removal diagram
Old Jun 8, 2016 | 08:50 PM
David Shiel
Default P. , good talking with you
this evening. The good news is I didn't damage anything, which I have been known to while "fixing" another problem.Dont asK!
Dave
Old Jun 8, 2016 | 08:54 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Dave
Just to let you guys know (if you didn't already) what kind of guy I am, called Dave tonight to see if he would install my sway bar ????
Old Jun 8, 2016 | 08:59 PM
David Shiel
Default Absolutely an excellent
https://www.youtube.com/watch?v=t69TBcBMHmw
sway bar instructional video. Can't miss with it. Should save guys like me a lot of grief.
Thanks,
Dave
Old Jun 8, 2016 | 09:11 PM
73Corvette's Avatar
73Corvette
Do you get to pick which way he installs it?
Old Jun 8, 2016 | 10:00 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
I will leave that up to you Steve !!!!
Old Jun 9, 2016 | 08:58 AM
David Shiel
Default I am available any time,
and I will install them upside down if you wish. I am an expert at how to do that! The 2" rise in the front looked cool, and I just adjusted the mirrors and turned up the radio to drown out the groaning and popping noises. Us old guys may have lost half our faculties, but we can still improvise to cover up our disorientation. I think we are on to something here!
Dave
To Cultrag-- help!!!!
