So I think all the squeaks I'm hearing are coming from my radio bezel, specifically the upper right hand corner. I could have sworn I read some threads over a year ago detailing how some people fixed this. Does anyone have any suggestions? I've tried searching but I'm not coming up with much.
I imagine I could shove something behind there but I don't want to bezel to stick out more than it already does. I'm not sure if it is coming from one of the connectors that hold it in the dash or if it's from the bezel rubbing up against the dash pad.
I've had it out a dozen times. None of the tabs are broken. I'm not sure about the pins but I'm fairly certain they are fine. I'm going to remove it again to adjust my shifter and check for sure. I may mess around and see what options there are. If anyone has any recommendations it would be appreciated.
