Front Cover Alignment. Do I Need To Drop The Pan???
Old Jun 13, 2016 | 10:28 AM
Rob 02's Avatar
Rob 02
Default Front Cover Alignment. Do I Need To Drop The Pan???
When you replace the front engine cover, is it necessary to drop the oil pan? I know it would be ideal for proper alignment but I'm kind of in a tight spot.
Old Jun 13, 2016 | 11:19 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
If you drop the pan, to replace the FRONT cover, I believe you might risk not having the REAR cover in proper alignment, also. I removed just the front cover of my engine, to throw on a new timing chain, while I was in there replacing the balancer. I made sure the front cover was in alignment using the SACCITY Corvette alignment tool, properly snugged the front cover in place, and I've been OK....
Old Jun 13, 2016 | 11:47 AM
Rob 02's Avatar
Rob 02
Thanks leadfoot4. I just checked out that tool on his sight. It looks like I have to remove the seal I installed but I can't think of any other way. Awesome!
That tool is affordable too.
To Front Cover Alignment. Do I Need To Drop The Pan???
