Climate control
Old Jun 13, 2016 | 09:47 PM
johnrehklau11@gmail.com's Avatar
2nd Gear
Default Climate control
Hi , my climate control reading go eradicate when in is raining or I go through a car wash somrtimes. My interior display in stuck on 69 degrees , but when its wet outside in may read almost anything from -3 degrees or 10 degrees or anywhere in between until it dries out. Any help. it a 2003. Thanks John
Last edited by johnrehklau11@gmail.com; Jun 13, 2016 at 09:50 PM. Reason: More info
Old Jun 13, 2016 | 09:58 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
outside sensor could be bad, lower pass side at radiator !!! you go though a car wash
Old Jun 14, 2016 | 01:31 AM
BigGun's Avatar
BigGun
Your ac will not work correctly with that sensor malfunctioning. They are not expensive and easy to replace. Check the wires and connector as that is often the problem.
Old Jun 14, 2016 | 06:58 AM
runner140*'s Avatar
runner140*
What Pounder said ambient temp sensor AND, stay away from car washes. Written by someone who drives in the rain....two to three times a week.
P.S. Google ambient temp sensor on a C5 Vette. Look at the picture and look for it on the right (pass.side) on radiator area ...frame rail. About $15.00- 17.00 at one of our vendors.
Old Jun 15, 2016 | 07:16 PM
2nd Gear
Default Ambient temperature sensor
[QUOTE=runner140*;1592419129]What Pounder said ambient temp sensor AND, stay away from car washes. Written by someone who drives in the rain....two to three times a week.
P.S. Google ambient temp sensor on a C5 Vette. Look at the picture and look for it on the right (pass.side) on radiator area ...frame rail. About $15.00- 17.00 at one of our vendors.[/QUO
Found connector was not plugged in. Thanks for telling me where to look. John
To Climate control
