TPMS relearn procedure
Old Jun 14, 2016 | 01:19 PM
Corvette Monkey's Avatar
Corvette Monkey
Default TPMS relearn procedure
Hi everyone,
I had a failing front right tire pressure monitor so I ordered a new sensor on Amazon (ACDelco) and had it installed.
But the dumb thing won't program at all. They tried at the shop and I've tried by going around with a magnet.
I'm wondering if I need to do some trick to get the dumb thing to turn on? Or did I just get unlucky and get one with a totally dead battery?
Thanks for any help.
Old Jun 14, 2016 | 02:10 PM
mrlmd's Avatar
mrlmd
Did you get the right one for your year? The early and later ones are not interchangeable with the receiver in the car.
Old Jun 14, 2016 | 02:18 PM
Corvette Monkey
This is the one I got:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Amazon said it was the right one for my car!
Old Jun 14, 2016 | 02:25 PM
Robert Perkins's Avatar
Robert Perkins
So you have a 2001 to 2004 Corvette if so the sensor should program with a magnet. Follow the procedures in your owners manual.
Old Jun 14, 2016 | 02:29 PM
Corvette Monkey
But the new sensor doesn't trigger with a magnet. The other three do.
That's why I'm wondering if there's some way to turn the new one on?
Thanks.
Old Jun 14, 2016 | 02:51 PM
Corvette Monkey
I have a 2002 Corvette.
My brother bought it new and babied it in a ridiculous fashion. His bare hands never touched the steering wheel. Then he sold it to me about 10 years ago.
Originally Posted by 8VETTE7
The magnet turns the sensor on so to speak. It wakes it up and causes it to send an identification signal to the receive in the car.
Does this mean if the magnet isn't activating it that it probably has a dead battery?
Thanks.
Old Jun 14, 2016 | 06:40 PM
popshumphrey's Avatar
popshumphrey
St. Jude Donor '16
You can also buy a donut type magnet at Home Depot that would fit around the valve stem. They are pretty cheap and may work.
Old Jun 14, 2016 | 08:20 PM
Corvette Monkey
I went out and tried again.
I used both the circular magnet made for the job that I have and a huge magnet.
The circular magnet trained the front left no problem, but got stuck on the front right again.
Then I tried my super magnet (it's replacing my Amazon link with a Home Depot link but I think it's the same):
And that did the same thing. Trained the front left no problem and stuck on the front right.
Is there some procedure that might turn the dumb thing on? Like putting it in some sort of learn mode and then letting air in and out of the tire?
Thanks.
Old Jun 15, 2016 | 12:33 AM
Rick369's Avatar
Rick369
I assume you are using the relearn process through the DIC.
Old Jun 15, 2016 | 06:28 AM
vigman's Avatar
vigman
It is possible you got a dud sensor...
It is also possible it got over torqued and broke.
You don't need to install the sensor to test it..
BUT once it programs & not mounted in the rim.... the car will think it has a flat.
The system is pretty dumb so it wants to SEE 4 sensors ( one at a time ) but you could have 4 in your lap.. and it will register them in the order presented.
The magnet closes a switch in the sender, which turns on a battery, which starts the data stream for the receiver to grab...
Mike
Old Jun 15, 2016 | 07:59 AM
If your magnets are training all the other sensors, I would have to say the one sensor is bad. Here is a thought though - try driving the car for a few minutes, then try the training process again. If that doesn't work, I'd suggest returning the one sensor for a replacement. And when that comes in, do the training procedure before you actually install the sensor in the wheel to make sure it will sync to the car.
Old Jun 15, 2016 | 02:56 PM
Corvette Monkey
I just drove around for several minutes then tried the learning again and still no luck.
It's sad, but I now remember how to put it in tire learning mode without even watching the video!
Old Jun 15, 2016 | 03:18 PM
huesmann's Avatar
huesmann
You're sure you got a magnetic TPMS and not one of those radio TPMS?
To TPMS relearn procedure
