Code 34...? MAF??
Old Sep 9, 2002 | 05:18 PM
Dettho's Avatar
Dettho
Navigator
Default Code 34...? MAF??
Code 34...? MAF??
The car runs really bad
If i let the engine come up to
3000-4000 RPM when driving, it loses power.
if im gently with throtle
it runs ok.
It started a few weeks ago with idle problems,
sometimes i lost my idle, so i figured that was a problem
with the IAC.. and now i ended up with this new problem
so i guess that both problems relates to the MAF??? :confused:
if there is a problem with the MAF do I need to replace the whole
unit??
Thankful for any sugestions.
Old Sep 9, 2002 | 05:46 PM
scool93535's Avatar
scool93535
Default Re: Code 34...? MAF?? (Dettho)
Codes are usually given as P0101, I can't figure out what code you are seeing? :rolleyes:
