C5-Tech Can the F45 shock be tested?
Old Sep 9, 2002 | 06:20 PM
gonbad's Avatar
gonbad
Default C5-Tech Can the F45 shock be tested?
So can the F45 shock be tested to see if it is functioning within spec?
Old Sep 9, 2002 | 09:39 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: C5-Tech Can the F45 shock be tested? (gonbad)
If a shock is faulty,a RTD (real time dampning) fault code should be set and can be acessed through the DIC...You can also disconnect the shock electrical terminal and measure the resistance across the 2 terminals...Should be 9.5-15.5 ohms :yesnod:
Old Sep 10, 2002 | 12:35 AM
EHS's Avatar
EHS
Default Re: C5-Tech Can the F45 shock be tested? (C-5 TECH)
I guess I had a similar question -- does a code get set if the shock is just simply worn out? Or does it have to be defective?
Thanks.
To C5-Tech Can the F45 shock be tested?
